Question about Maytag EPICz Electric Dryer
My may tag won't turn on, i know it's getting electricity because the interior light turns on, but we had a bad storm and it hasn't worked ever since...is there a reset button on the thing?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryermy may tag won't turn on, i know it's getting - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 06, 2010
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
Headlights won't turn on
a. Your Light Switch on the Dash has gone bad....
b. It became Unplugged
More than likely, your Switch actually went bad...
Apr 08, 2013 | Mercury Sable Cars & Trucks
Interior light not turning on. Temperature not showing up either. Brand new out of the box. Plugged in and it lit up, then turned off. Now won't turn on (light won't turn on) Unit turns on and
Sounds like a poor connection in the control or a faulty control module, I would return it as faulty for a new one. They seal those units up pretty good so we can't fiddle with them. Everyone gets a lemon sometimes.
Sep 06, 2012 | Whynter (WC16S) Wine Cooler
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
1998 Ford Windstar Minivan: 1. I sometimes get an extended crank when trying to start engine after I've made a short trip. 2. My interior lights won't go out after I turn the engine off, so I...
YOU MAY HAVE A BAD DOOR AJAR SWITCH. HOWEVER, YO HAVE A TIMER THAT SHUTS OFF THE INTERIOR LIGHTS AFTER 300 MINUTES. IT'S CALLED A BATTERY SAVER FEATURE. TEST IT OUT.
THE EXTENDED CRANK MAY BE A CHECK VALVE IN THE FUEL PUMP IN THE TANK, ALLOWING PRESSURE TO DROP WHEN YOU TURN THE ENGINE OFF.
OR A BAD FUEL PRESSURE REGULATOR ON THE ENGIEN FUEL RAIL.
TRY THIS TEST, TURN KEY TO "ON" POSITION, WAIT 5 SECONDS, SHUT OFF KEY FOR 30 SECONDS. TURN KEY ON, WAIT 5 SECONDS, THEN START ENGINE. IF IT STARTS RIGHT UP, YOU ARE LOSING FUEL PRESSURE WITH ENGINE OFF.
THIS BUILDS UP PRESSURE IF IT DROPPED DURING SHUT DOWN.
REPORT TEST RESULTS.
PLEAE RATE, THANKS
May 16, 2011 | 1998 Ford Windstar
I have a hp 2207 monitor was working fine then we cut it off one day before a storm and since then it hasn't worked the blue power button at the top flashes on an off and the monitor flickers in and...
Not sure how much this will help you now, but unplugging your device is the only way to really protect it during a storm. Even turned off, your equipment is still subject to receive any electrical spikes that come through the lines
May 09, 2011 | HP w2207 Monitor
Buick Regal 93 Light/window electrical problems.
start with the basics... check the bulbs... then the fuses.... after that use a multimeter to see if power is going to the lights that are not working.... bad grounds will cause the lights to be dim or not work.
Aug 31, 2008 | 1993 Buick Regal
Electrical issue
It might be a electrical wire shorting or bad.
I had solved a majority of my problems by getting my electrical system looked at (turned out a brake wire was bad, and several needed to be replaced.)
Jul 20, 2008 | 1994 Buick Century
Maytag EPICz Electric Dryer Logo
787 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
