Question about Philips Magnavox MWD7006 DVD Player
Connecting I lost my manual in moving. I need to know how to connect the MWD7006 to my RCA television set . I am connected to the satellite system DISH. I am also having trouble playing my DVD's. Ray Bruno
    Problem Solver:
  • 5 Answers
Here's a link to the pdf manual at Funai's site that I managed to dig up to supplement the above solution. It's a 10mb download: MWD7006 Manual.
Posted on Sep 21, 2008
  • 8,596 Answers
In general, you want to run red, yellow, white (composite or a/v) cables from the out of your sat box to the in of the Magnavox. Then run a 2nd set of r,y,w cables from the out of the Magnavox to the in of the TV (there may be one or several places to plug it into TV). If your sat box is an HD sat box, you probably won't get it to work with this Magnavox. This unit was jointly manufactured with Funai corp, so you will have to call 1-800-605-8610 for tech support.
Posted on May 29, 2008
Got a 19" LG LCD
To convert a LCD Monitor into a TV
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
I purchase a Panasonic Blu-Ray Home Theatre SC-BT330PCK with the intent of using it as a surround sound system for my TV and having a Blu-Ray as a bonus. Is it possible to have them work independently?
Hello there,
Yes it is possible and relatively simple to do. I suspect you have only connected an HDMI cable from the Home Theater system (HT) to the TV. This cable only sends audio and video to the TV from the HT system - it can't be used to receive the audio from the TV back to the HT.
To get audio from the TV channels through the HT speakers, you will need to connect a separate audio cable from the AUDIO OUT sockets on the TV to the HT. This can be either a Digital Optical cable (connects to socket ringed in green) or an RCA type stereo audio cable (connects to AUX sockets ringed in red).
If you are using a cable or satellite receiver, you should connect the receiver directly to the HT rather than the TV. You would also need to select the correct INPUT on the HT when you want to use the speakers for the TV channels. This will be DIGITAL 1 if using the digital optical cable or AUX if using the RCA stereo audio cable.
The audio connections are explained on page 16 of your user manual and input selection is explained on page 23. If you don't have a manual, please let me know and I can supply one.
I can draw you a diagram showing how to connect your TV to the HT and provide step-by-step instructions for setting it up, but you will need to let me know the brand and model number of your TV. If you are using a cable or satellite receiver, please let me know the brand and model number of this receiver as well.
Hope this helps.
Mar 22, 2011 | Panasonic SC-BT200 Home Theater Systems....
I have a 32 "
Check how you have the satellite cabled. I suspect that you have the video from the satellite to the TV but the audio cable going directly to the stereo. You probably have the DVD audio and video going directly to the TV. (I'm assuming you have the 32LA30rq and not the 32LA30rqd which has a built-in DVD and thus has the audio connection inside the TV.)
Since you don't mention which connection you are using for the DVD player and for the satellite, I will just mention the basics. If your DVD player is connected to one of the HDMI ports, that cable carries audio and video between the TV and the DVD player.
Devices that use component video cables use two separate cables. One cable with two sets of three RCA plugs carry the video; a second cable carries audio with 2 RCA plugs on each end. When you connect these, you do not have to connect the audio to the TV. (Similarly, a composite video connection can be modified for one line with the video signal going to the TV and the audio cable going to a speaker system.)
If my solution is correct, you may want to rearrange things. You can connect the satellite audio out to the TV audio in at the same location as you have the satellite video in. Then connect the TV's audio out (to the right of the component 2 in and above the coax audio out) to the stereo. Then switch the TV speakers off to use the stereo - Menu > Sound > Other Settings > Speaker On/Off. Then both devices will play either at the TV speakers or the stereo depending on the state of the TV speaker setting.
The manual is available here: .
I hope this helps.
Jan 20, 2011 | RCA Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Dec 29, 2010 | Televison & Video
Satellite connection to tv doesnt recognize
At least you know the set does work. I'm also assuming your satellite receiver is working and that all your cables are good.
There are two ways to hook up to the TV: RF (antenna) and the A/V jacks. Maybe the seller was using the RF input (the threaded round connector where you screw on a cable connection, then choose channels with the set's tuner), and you're trying to connect using the A/V jacks (the red, white and yellow RCA jacks). If that's the case you need to switch the TV to those inputs. You may need the original remote to do that if the TV doesn't have a front panel TV/AV button.
The other possibility is you're connecting the satellite receiver to the RF connector and the TV isn't on the right channel (usually channel 3 or 4). If you're using the RF input, have the TV autoprogram and it should find the channel. Most sets can do that from the front panel menu button.
Hope this helps. Thanks for sing Fixya!
Feb 19, 2010 | Quasar SP-3235 32" TV
Connecting Toshiba Satellite A105-S2071 to TV with S-video/RCA
after hooking the pc to the tv make sure the tv is set to the correct input, hit alt+f5.
Aug 06, 2009 | Toshiba Satellite A205-S4617 Notebook
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
Mar 02, 2009 | Daewoo DV-T47N VCR
How do I install a channel to receive satellite programmes? My model is LE19R8
If you have a satellite and it is connected with coaxial cable put the set to channell 3 or 4. If the satellite is connected with RCA cableput the set on that source the cable are connected to. No need to program the set. Use the cable remote to change the channels just use the tv remote to turn the set on and off and for volume.
Aug 19, 2008 | Televison & Video
Hooking up a magnavox MWD7006 DVD player to a APEX TV
honey and guest: connections: Red, white, and yellow composite from out of cable/sat box to in of this dvd, and then a 2nd red , white and yellow cable from out of this player to in on television. Every television calls the correct channel something different - make note of where you plug the r,y,w cables to TV -- it may be labelled video1, video 2, av1, av2, input1, ext 1, etc. Turn tv to correct input/av/source/video channel. Call 1-800-605-8610 for further assistance.
Jan 13, 2008 | Philips Magnavox MWD7006 DVD Player
The PIP puts a smaller picture on your main picture. Usually, the smaller picture is generated by a second source, such as a VCR. The VCR must be connected to the main cable signal and connected to the TV through the red, white, yellow RCA jacks. The VCR picks the smaller picture whilt the tuner in the TV picks the main pucture. The PIP circuits digitally add the smaller picture to the larger picture. The PIP cannot be used to veiw 2 different channels at once on satellite systems because the satellite receiver sends only one channel to the set at a time.
Aug 22, 2007 | RCA F32665 32" TV
Philips Magnavox MWD7006 DVD Player Logo
89 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
