Question about HP Pavilion A730N (PJ510AA) PC Desktop
GREEN LIGHT IN BACK OF TOWER COMES ON. BUT POWER TO THE TOWER AND FANS DONT CUT ON.. WHATS THE PROBLEM
  • 4,234 Answers
The power supply generates 3 different voltages for the system. The most common cause of the symptom you are describing is a loss of the 5V supply line. This is an internal failure of the power supply that sometimes can be easily fixed, but the cost of repair is likelt to be higher than a replacement supply. A typical power supply will cost around $40. If you have another system around, swap the power supplies between the two. If the system now appears to work, you have confirmed the problem.
Dan
Posted on May 10, 2010
  • 3,600 Answers
Coul.d be anything but most likely the power supply has failed. I have replaced a few of them on that model. However you could have a bad memory stick a plug could be loose on the hard drive or a host of other minor things it could be. if there is no beep when it is turned on then I would emagine it's the power supply or the memery chip. Hope this helps and thank for using fix-ya
Posted on May 05, 2010
  • HP Master
  • 3,866 Answers
In most newer PC's a power supply will not come on for a variety of issues:
1. Memory module
2. Over heat
3. cables
The list goes on...
Things you can try here. Try a different memory module.
Check the power supply of course.
Check your cables.
Thanks I hope this does help please do leave you ratings on all experts solutions you feel that helped.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
Wont power up
My wont turn on too, There is a orange light on the tower, Green on the left, Battery ovel, If I push the restart button, also switch the power supply switch in the back, also unplug from it, Sometimes does it, Do ou know whats causing this to happen, Please let me know Thanks
Jan 26, 2013 | Asrock K10N78M Motherboard
Power supply problem on pavillion
What are you heating with a dryer? i have never heard that one before? Who came up with that idea and why? Are the fans comming on? Curious?
Dec 26, 2012 | HP Media Center m7250n (ED842AA) PC...
Flashing green light on power supplyonly fans come on at start up
just open ur pc case replace the ram and all connections for 5 to 10 min clean dust inside pc and also clean ram and put back in to pc and restart i hope ur comp will be right back to normal!
Aug 02, 2010 | HP (152769-001) (152769001) 250-Watt Power...
Wont power up green light on back is on but
Most likely a failure in the internal power supply of the tower. Replacements are around $50 if not under warranty.
Oct 09, 2009 | HP Compaq Presario SR2150NX PC Desktop
Lotos cut 40 plasma cutter, not firing
Test all the mosfets, good chance one or more are failed.
Jul 28, 2009 | A & A Manufacturing Ramsond 40D Plasma...
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Feb 13, 2008 | Hitachi CP-X327 Multimedia Projector
HP Pavilion A730N (PJ510AA) PC Desktop Logo
331 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
