Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Need the belt size on a 15hp ohv kohler command crafstman 42 inch deck
  • 5 Answers
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Posted on Apr 25, 2009
panilling9
  • 284 Answers
SOURCE: Looking for manual for Craftsman 917.256552 15HP
if you go to sears.com click on parts direct
enter your mod # and to the right of the next page says get manual click on that and then click on view manual and it should come up for your mower
Posted on Jun 09, 2009
  • 376 Answers
SOURCE: LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Posted on Jul 04, 2009
  • 133 Answers
SOURCE: need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Posted on Jul 29, 2009
  • 3 Answers
SOURCE: Craftsman Kohler 15HP 42
it deffenetly sounds like the coil is bad . as the motor increases in temp. the coil pack expands thus loosing positive charge. change it if it has points filr them a little too remove the tartar you should have a sharp blue spark
Posted on Nov 15, 2010
Mower belt will not engage ?
First is to check the belt diagram and make sure your belt is on the correct side of the engagement pulley. This would be the one on the left side of deck with a spring attached.
Oct 06, 2016 | Mtd Arnold Corp RearMounted Bagger for MTD...
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
How do I hook up a 15hp kohler engine to a 13hp lawnmover
will bolt holes physicaly fit ? if so then bolt to frame and i suggest using blade from new mower on old frame
Oct 15, 2014 | Kohler 15HP Replacement Engine SV470-3200...
What size belts do i need for my poulan riding tractor model 733-864 42" deck 14.5 hp
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Jun 15, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
What size belt for powr kraft 18/42 industrial commercial twin cylinder automatic hyrostatic dive .need deck belt.
My mower is 18/42 power kraft, limited addition, hydrostatic. I need to replace deck belt because deck belt was bitten by mouse. May I know belt routing and how to replce it. Thank you.
Jan 28, 2012 | Garden
Need belt for craftsman 42 inch deck size, what size is it
You will probably need more info.
The belt is listed in your manual, if you have one.
If you can bring the belt in, a good auto parts store will have it in stock.
If you have the model no. we may be able to find the size for you on the internet.
Gary
Aug 21, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Apr 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Yard Man 42'' Drive Belt Install
it is a mtd mower ,however you should be able to go to a tractor supply store with the decksize and the engine size and get the proper belt.AGAIN(TSC) store,OR TSC.COM HOPE THIS HELPS
Jun 08, 2009 | Mtd Garden
Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
413 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
