Question about Canopus ADVC-110 A/D Converter (77010150105) Video Capture
CANNOT GET TO TRANSFER MY VIDEO FROM MY CASETTE CAMCORDER TO THE COMPUTER USING MY 4POINT FIRE WIRE CABLE,THEY SAID I CAN USE THE ADOPTER AND THE FIRE WIRE CABLE IF I DON'T HAVE THE JACK FOR THE IEEE 1394 CABLE BUT I CANNOT GET TO DO THE TRANSFER TO MY COMPUTER,I DONT KNOW WHAT TO DO.
  • 3,600 Answers
You will need to hook your camera up to the fire wire to transfer itto the converter so connet the firewire to the camera and hit the play button however I don't know if your converter has a program that finalizes the video once your done recording. On some camera's it will finalize the DV and then it is the only thing you can use to transfer to the DV converter or to your computer, let me know what type of camera you have and I can tell you how to connect it to do it.
Posted on May 05, 2010
What cord shoukd i buy to connect it to my laptop
The best way to transfer video from a camcorder to pc is with the use of an i-link (or fire wire) cable. It allows for fast transfer. You will probably have to get an adapter for your laptop. I purchased a pc card fire wire adapter from Best Buy last week for $9.99 and the fire wire for $36.99. Then just make sure you have some type of movie editing software and you should be set....
Hope this helps :)
GOOD LUCK!
May 29, 2011 | Panasonic Palmcorder PV-GS12 Mini DV...
I want to load video from my canon MV850i. The video is on a casette at the camera. Nothing works. What drivers to I need to solve this. I am trying to use typical usb cable.
Hi, For transferring video from a cassette camcorder I recommend getting something like the Pinnacle Dazzle, http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+Video+Creator+Plus+HD.htm you connect your camcorder to it with the cables you use to connect it to a TV and it then connects via USB it also comes with easy to use software for transferring the video as well as editing it. If you need anymore help let me know =)
May 15, 2011 | Cameras
Having difficulty connecting the jvc gr-d370 to my computer using Windows Media. What must I do to retrieve the video from the camcorder using the USB cable?
I had this same issue. I solved it. The USB cable will NOT work to transfer video. You need a IEEE-1395 fire wire cable. I purchased the internal card and cable for under $20.00 for my DELL computer direct from dell. After you connect your camcorder to your computer, I clicked on windows photo gallery. Then in top left corner, click file and "import from camera or scanner. Your camcorder must be on video mode and play mode. Your computer should recognize the camcorder, click on it and then it will give you options, like you can upload and record direct onto DVD. I liked the option of uploading manually because if there are blank sections on the DV tape, the computer will stop uloading. Hope this helps.
Dec 28, 2010 | JVC GR-D370 Mini DV Digital Camcorder
How to transfer record to my laptopeduard
needs drivers to install camera to laptop. or In order to place taped videos to the PC, you need a Fire Wire port on your computer, a 6pin to 4pin fire wire cable, and a lot of hard drive space. One hour is about 14 gigs when transfered 100% uncompressed. After editing and compression though the file size is very manageable.
**For every minute you record it takes one minute to transfer to the PC*
or you need a usb videop capture to transfer video to your laptop
Sep 04, 2010 | JVC GR-D850 Mini DV Camcorder
Can hdc-tm20 connect a firewire cable?
From what I have heard this camera has no firewire, but it has USB download to PC and AV sockets, I hear that a new version soon will carry the firewire mode as I like many other camera user's do find that the firewire to PC connection is the best, but saying that if you record on the flash mem mostly you can plug that card into the latest PC's anyway, if you can do that then it will be very high def movies indeed.
I would not like to use a USB download cable as you will find picture suffers badly.
May 22, 2010 | Panasonic HDC-TM20 High Definition...
Need vista support drive
Since Windows Vista doesn't support USB Streaming, it's not possible to transfer the videos to the Computer using the USB connection.
However, you may transfer the videos to the Computer using an i.Link or an AV connection.
The AV port is similar to the Composite port of the TV.
i.LINK is the same as Fire-wire/IEEE1394. It is a D Shaped connector of either 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer.
However, it's required to have the Analog or the i.Link Capture Card installed on the Computer to stream Videos using the AV and the i.Link connection respectively.
It's required to purchase either a 4 - pin to 4 - pin or a 4 - pin to 6 - pin i.LINK / Fire-wire cable depending on the number of pins on the i.LINK / Fire-wire port of your computer (since Camcorder will have only 4PIN i-LINK, while the Computer may have a 4PIN or 6 PIN i.LINK port).
If your computer does not feature this port, you may contact your Computer retailer to install a separate i.LINK Capture card in your Computer.
The software and driver to be used for video transfer will be supplied by the computer manufacturer (if the computer came with an i.LINK interface) or else by the i.LINK card manufacturer.
Click on the below links to get the steps to transfer the videos to the Computer using the:
i.Link connection:-
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111921
AV connection:-
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
Mar 04, 2010 | Sony Handycam DCR-TRV460E Digital...
Want to transfer videos from a mini DV cassette to computer.
YOU NEED THE SHARP CD-ROM TO LOAD THE VIDEO DRIVERS ON YOUR COMPUTER TO RECOGNIZE THE CAMERA...PART # IS CDSKAA028WJ01
Dec 24, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Transfering video casette recording to my computer
if you want to transfer from VHS or an analog camcorder you need a capture card or TV card (some mother borad and graphic card have this on board).but if you have a DV camcorder check this: if your computer and camcorder have fire wire port (IEE1394) use it and otherwise use USB (low qualty). for software I could suggest video studio, adobe primaire (full or element) windows movie maker, or any othe program which comes with you camcorder. I hope this helps...
Oct 22, 2008 | Sharp VL-Z5 Mini DV Digital Camcorder
Transfer of video from Panasonic NV-GS50 tape to computer
You can only transfer from the card to a PC. You can record video on the card in .mpeg4 format.
Oct 09, 2006 | Panasonic NV-GS50 Mini DV Digital...
Open Questions:
Canopus ADVC-110 A/D Converter (77010150105) Video Capture Logo
126 people viewed this question
Top Canopus Televison & Video Experts
Yoav Shilon
Yoav Shilon
isaac johny
isaac johny
Josh Whitehead
Josh Whitehead
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
