Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I blew my connecting rod on my Briggs 20hp and replaced
I blew my connecting rod on my Briggs & Stratton 31P977 20hp lawn mower engine and replaced it. Could I have put it on backwards on the crank? The engine is misfiring.
  • Anonymous Mar 24, 2014
    A craftsman 20HP lawn tractor built 04 08 with a Nikki carburetor will run only on full choke or idle, but dies at full throttle. I have cleaned all passages in carb but, I did not replace any gaskets because none seemed to be torn or frayed. What could be the problem with this engine. The throttle seems to operate from the governor instead of directly to the throttle lever.
  • 3,600 Answers
You most likely have a bent or burned valve, if you put it at top dead center and apply some air to the cylinder see if you hear a leak from the intake or the exhaust pipe if you do that will tell you you have a bent valve. hope this helps and thanks for using Fix-ya.
Posted on May 05, 2010
  • 370 Answers
Yes it is possible to put them in backwards, there are triangles on the rod and crank that have to be on the same side in order for it to be correct. If it is missfiring you also need to check you timing key on the crank. since you broke a connecting rod I would only have to assume that you sheered the timing key as well.
Need to know where the fuel filter is located
FAQ: Fuel Filter Replacement ' Briggs & Stratton Engines
www.briggsandstratton.com/us/.../fuel-filter-replaceme...
Briggs & StrattonWith this Briggs & Stratton FAQ, you'll learn how a fuel filter works in small engines ...properly strain the gas before it reaches the carburetor in your lawn mower, snow ...and uneven operation; Clean filters conserve the amount of gas you need ... The fuel filter will be located either inside the fuel tank or fitted into the fuel line ...
Servicing the fuel filter - Briggs & Stratton
www.briggsandstratton.com > www > Support > FAQs
Briggs & StrattonIf you still need help, you can submit your question by clicking the Ask a Question tab.... Some filters are located inside the tank, others are fitted into the fuel line between the tank ... The size of the holes in the filter will determine the largest particles that can get through the filter, and the number of ... Lawn Mower Engines ...
Lawn Mower Engine Fuel Filter Installation - Briggs ...
Jan 01, 2016 | Garden
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.http://www.ehow.com/info_7929485_briggs-hp-twin-torque-specifications.html
Oct 02, 2011 | Yard Machines 155 Torque Briggs Stratton...
It won't start. Jumped the battery. change selenoid and only have a click
Is the engine installed on a mower? If not, do you have a good ground connection? If so, try using a jumper cable to go from the positive on the battery to the terminal on the engine starter. If starter good and no other mechanical problems (i.e. broken connection rod), it should turn.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton...
Need a procedure for valve adjustment on a briggs 20hp engine model 31p977
go to youtube type in valve adjustment on briggs,simple procedure.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Engine on riding lawn mower surging
Dirty air cleaner.
Clogged fuel filter.
Replace or clean both...
May 29, 2009 | Garden
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
398 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
