Question about HP Photosmart M415 Digital Camera
Broken green tab that keeps battery in place
Is there a replacement green tab that keeps the battery in place? I have somehow bent or broken it. The battery cover keeps battery in place, but is now not a tight fit. Is there a place to send camera to to replace if necessary?
  • 10,865 Answers
Yes you can send the camera to HP. Call them at 800-HP-DIRECT to get the mailing info. Joe
Posted on May 05, 2010
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
I installed a new magnetic seal on my Amana refrigerator. The new seal has been sitting in its box for about ten years. After installation, I realize it has lost its magnetism. Can I rejuvenate it somehow?
No. Never heard of this happening. Make sure that the door stop at the bottom hinge is not bent and keeping the door from shutting all the way. I've seen this alot. Also, if you soak the gasket in hot water for 15 minutes or so, it will soften it up and lay flat when you install it.
Feb 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Broken orange battery tab
Contact Pentax and see if they will send you the part, for the tab + S/H it should cost you approximately $25, although I have recently heard they will not provide these items to customers anymore. If they're no longer providing replacements, your device will need to be sent to them for repair (approximately $70 incl labour).
Or... Get a piece of tape and place it over the battery and close the casing, other "ghetto rig solutions" include folding a piece of paper, placing it atop the battery (between the battery and the closing cover) and closing the flap, the paper will hold the battery against the pins and allow function.
Dec 08, 2009 | Pentax Optio T10 Digital Camera
Paslode IMT90, will not come to life - Fully charged new battieries and gas. Was working fine but now green flashing light will not activate, hence gun is dead....
You may want to check the battery connection terminal inside the housing. Sometimes the tab will break off and not be making contact with the battery. Use a flashlight to see if the tab is missing or bent out of the way. If so you will have to replace molded circuit assembly.
Nov 05, 2009 | Tools & Hardware - Others
Risograph: set master disposal box in place warning won't go away
sounds like the sensor is stuck when you put the box back in make sure it is square and sometimes if you open the front door whilst replaceing it the close rhe door after the reset can work check the sensor arm .. this hangs down in the middle where the box goes back in on the face plate of the side of the machine
Jul 30, 2009 | Riso RZ220 Duplicator
Cover open message and there are no covers open
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Apr 24, 2009 | Office Equipment & Supplies
Charger socket broken
That little black thing goes into the charger so without it, or something to replace it, you can not charge, unless you somehow found a way to take out the battery and charge it outside of the ds. I would highly recommend sending it back to Nintendo or something like that.
Jan 24, 2009 | Nintendo DS Console
Acer Laptop - key topped popped off
Yes it does snap back on. Place it where it on top of the retainer and press down gently until it snaps into place. You may need to work it around a bit in order to line it up. If it doesn't snap on or doesn't stay, check the bottom of the key to make sure the sides where the retainer goes into hasn't collapsed, or check the retainer to see if one of the pins that snaps into the key isn't bent or broken. If the sides are collapsed or a pin is bent, you can bend the side or pin back into place with a small screwdriver, be gentle as not to break it. If it's broken it will need to be replaced.
Jul 16, 2008 | Acer TravelMate 2300 Notebook
Broken Part - Battery Door
It is not too easy to change the door, but can be done.
You have to "tear" away the rubber from the handle. There are a couple of screws under the rubber to remove. The righter part of the batteryholder is kinda loose at that point. You can use a little screwdriver to open enough gap from right side from the point A. Then you can slide the battery door loose and replace a new one.a298e8d.jpg
Sep 25, 2007 | Konica Minolta DiMAGE Z5 Digital Camera
HP Photosmart M415 Digital Camera Logo
53 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
