Question about Porter Cable Tools & Hardware - Others
I have a PC Model 136 Belt sander--I know it's older than dirt, but it was a gift from an old friend and has served me well for many years. My problem: For the past several years, it has been breaking belts soon after installation. After careful inspection, I find nothing wrong with the sander. I think the problem is with the modern 3" X 21" belts. My question: Is the tension created by this sander too much for modern belts? I buy my belts at Lowes and I don't see that they carry any special category for strong belts. It looks as though the modern belts don't have the overlap and bond that the old ones had. Solutions? If the above is true, are stronger belts available? Is there a weaker spring I can install in this trusty Model 136? Thank you, I am a Porter Cable affectionado. Fred Beckmann
I also own a PC Model 136...it is still working Great...I have been useing "Diablo Belts" from Home Depot and have no problems what so ever...
Posted on May 27, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
I also have a PC Model 136 belt sander. Although I don't do a lot of woodworking, it has proved to be a workhorse when I needed it. I don't have a problem with breaking belts - the last ones I bought at OSH. The problem that has developed with mine is getting the belt alignment adjusted, after a belt change, to not run against the sander body. A little banging (with my hand) will correct the problem. I have serviced it to free up the fulcrum, but it still jams most of the time. This doesn't address your problem, but it is good to hear of someone else who appreciates the fine older tools. Just a further thought - the newer belts I have purchased are bi-directional, e.g., they will run either way. I know that the older belts had to run one way and running them backward could - almost surely would - cause them to break. I won't insult your intelligence to suggest that that might be your problem.
Posted on Jul 07, 2010
My Hitachi Belt sander SB75 the sanding belt moves off rollers as soon as applied to work piece how do I stop this happening?
There is a belt adjustment know on the side of the sander. Turn the adjustment know back and forth while the sander is running until it centers itself.
Jan 01, 2011 | Hitachi 3 In X 21 In Belt Sander, 2 Speed,...
Should I buy an old Delta sanding Center? Is it wise to buy an older Delta sanding center 31-730F Not all parts are still available. They want $250.00 for the sander
If it's the kind with a round disk sander and a wide belt sander, as far as I know belts and disks are still available. There is not much else to wear out. Make sure you test it before purchase.
May 12, 2010 | Delta Machinery Sanders Sanding Center -...
Older makita belt sander shocking me while using
You are probably missing an insulating ring / washer that goes between your bearing and your armature (the shaft on the center part of the electrical motor. The fact that it does not have a grounded plug is not necessarily an indicator of age or safety so don't be too afraid. DeWalt still uses two prong cords to this day. In these tools they offer what is called double insulation, simply non-conductive material that separates electrical components from the user. The part number for the insulating ring is 681623-9. If you ever wanted to ground the tool you don't really need any special switches you just have to attach the grounding line to the metal casing.
Feb 15, 2010 | Makita 3 x 24" Belt Sander
How do I release the lock on my Craftsman belt sander to lighten the belt. It's an old Model # 315.1172
I checked Searspartsdirect.com for that model number and they listed that number, but with an extra 0 at the right end. I couldn't find a belt release lever illustrated anywhere like that on my old Craftsman belt sander. On mine, you just flipped the lever either forward or back to release and tighten the belt. (still works great) There is a spring that pushes the front roller assembly forward when the lever is operated.
Dec 03, 2009 | Cars & Trucks
Need a manual for a Craftsman belt & circular sander
I found a PDF file on Sears.com website for the original manual for my belt / circular sander.
Oct 21, 2009 | Tools & Hardware - Others
HOW TO CHANGE THE BELT ON A BELT SANDER
There is a lever on the side of the unit, flip the lever and then slid the belt off.
Jun 13, 2009 | Makita 9404 4'' x 24'' Belt Sander
I have a type 2,#92 heavy duty sander,length of right angle sander is 14".. approx 35 years old............need brushes. whee can I find these please...
First try Black & Decker Serves Department. At some Hardware stores (ACE, True Value, etc)they stock brushes in the back room.
Jun 12, 2009 | Black & Decker 4.3A 6" Heavy Duty Right...
ORBITAL sander screeching (NOT belt sander!)
No, sounds like a bad bearing. But depending on who made it parts may be available. Don't know if it helps but I use a co. called GRAINGER, they are pretty helpfull. good luck.
Apr 26, 2009 | Tools & Hardware - Others
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Tools & Hardware - Others Logo
812 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
