Question about Whirlpool Kitchen Ranges
HOW DO YOU ADJUST SIMMER FLAME ON AN LP RANGE WITH SEALED BURNERS MODEL WFG374LV01 THE FLAME IS MUCH TOO HIGH WHEN SET LOW
    President:
  • 949 Answers
The simmer adjustment is behind the knob for each burner.
Here are the instructions from the installation guide. Let me know if you have questions.
Posted on May 05, 2010
I have a Belling Richmond dual fuel cooker (electric & LPG) and can't simmer anything on the burners because the flame is too high even at the lowest setting
Most gas ranges and cooktops are set for natural gas at the factory. If the flames are too high this could be an indication the range or cooktop was improperly converted from a natural gas setting to LP, (Liquid Propane) gas setting. Contact your installer or local Gas Company to correctly convert the range or cooktop.
Dec 10, 2016 | Belling Kitchen Ranges
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
I have a Kitchenaide model KGSS907SBL01 gas range. Everything works fine except that we find that the amount of heat generated is disappointing. This seems to come from the fact that the top of the grill...
It would seem like reasonable thing to do.However the adjustment is typically for the low setting so you can adjust just the small flame just enough to simmer a pot without the flame going out from being so low its susuptable to going out on the low setting, also it so you can adjust the flame smaller so on low it isnt too high,causing it will boil when you intend to only simmer a dish your cooking. A question;is it all burners and have they always been that way?
Gene
Aug 13, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
Simmer flame to high
Tighten your spuds down with good fitting wrench till you get that flame how you like it. This video shows how to convert a stove from natural gas to LP gas. It shows you how to adjust them burners though. Take a looksee:
Nov 17, 2010 | Frigidaire FGF316 Gas Kitchen Range
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
Gas cooktop flames are too high
are you natural gas or lp
and is your range set correctly
is your flame blue
or orange
Sep 15, 2009 | Kenmore Kitchen Ranges
Flame on my Whirlpool gas stove burners are too high on low
either turn down the gas knob or turn knobs to lowest setting without going out. That is about your only options
Aug 25, 2009 | Whirlpool SF367 Gas Kitchen Range
Burner controls
if you remove the knobs from the unit nad look closely doen the shaft of the protruding valve stem you should be able to see a slot for a regular screwdriver to fit down, its gonna have to be long adn thin but that is the flame adjustment screw,
put the flame down to low and use a pair of pliers to hold the valve stem from turning as you try to adjust the screw, turn it very slowly you seel an adjustment happen (dont really know if its counter clockwise or clockwise, but youll figure it out playin gwith it for a bit, just remember to hold the shaft from turnig, and although your turninf the valve down to simmer it does not afffect the high setting
Apr 06, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Kitchen Ranges Logo
338 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
