Question about Craftsman Garden
Is my Craftsman Mulcher lawnmower a 4 stroke or 2 stroke engine??
  • 2,100 Answers
It should be a 4 stroke, the only thing I can find on it is the mulcher blades, set up called a side discharge mower. It has a 5.5 HP ,22 inch, briggs and stratton engine. Hope this helps.
Posted on May 06, 2010
How do I change the oil in my 4 cycle engine Craftsman Leaf Blower?
If this is a hand held machine. It doesn't require engine oil changing.!
Although its a 4 cycle engine. its basically a 2 stroke engine with valves. It runs on the same fuel/ oil mix as a normal 2stroke engine. 50:1
Apr 21, 2016 | Craftsman Garden
Do i put 2 stroke or 4 stroke in a 148cc engine
does the engine take oil? if it does then it is a 4 stroke and does not require mixed gas. if it doesn't have its own oil then it is a 2 stroke and requires mixed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 25, 2013 | Briggs & Stratton Briggs Stratton...
My Craftsman 5.5 hp 14" rear tine tiller starts but doesn't run for long. It blows black smoke and quits. The gas is new and the oil is good.
Black smoke looks like it's burning too much oil. If it is a 2 stroke engine try a lower ratio of 2 stroke oil to gasoline mixture. Make sure you are using 2 stroke oil!
If it's a 4 stroke engine find out why and or how the oil is getting burned.
Sep 10, 2013 | Garden
I got hold of a sanli 350 lawn mower 4 stroke the people gave me a bottle of 2 stroke oil with the mower is this the right oil to use
No No No No!!! If your mower is definitely a 4 stroke then do NOT put 2 cycle engine oil in it (and I hope they didn't either). Drain out whatever's in there completely and put standard 30 wt. oil in there. Not 10W30, but straight 30 weight. Use synthetic even if you want longer engine life.
Aug 21, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a Poulan 625 push mower. What type of oil should I use in it? I can't find my manual.
If it has a 4 stroke engine, as most lawnmowers do, then you just car engine oil. Very occasionally you come across 2 stroke mowers.
The way to know if it's a 4 stroke or 2 stroke engine is, if it has an oil tank it's a 4 stroke engine. If there's only the one tank, i.e. you mix the oil with the petrol then it's a 2 stroke engine.
If it's a 2 stroke engine you mix petrol and 2 stroke oil at a ratio of 40:1
Jul 12, 2011 | Poulan Garden
How to fix a 3.5 lawn mower?
HELLO,
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
How do i tell a victa 2 stroke from a 4 stroke?
two stroke mowers will have a picture of a oil can on the fuel cap,if it doesn't it is most likely a four stroke.
four stroke mowers will have a fuel cap and a oil cap as well.
Dec 12, 2010 | Honda Garden
Lost my manual on my Craftsman LTS 2000 20 HP-wondering if I can mulch leaves with my lawnmower and how?
They make a mulch cover for the discharge chute and a good set of mulcher blades. You need the 9 digit model number from the label under the seat and you can get them from sears
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2 stroke gas mixture in 4 stroke lawnmower
Your carburetor jet is probably clogged with oil. Try an additive in the gasoline -- something for cleaning injectors -- it will only require a small amount -- use the same ratio as described on the label.
You'll have to keep starting the engine to get the cleaner into the carburetor. After you've done this several dozen times, let it sit for a day.
If this doesn't clean it out, you'll need to take the carburetor apart and clean it.
May 05, 2009 | Garden
Garden Logo
245 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
