Question about HP w1907 LCD Monitor
I have had the monitor for over a year .computer stoped working added new machine.no input signal using 5450 512 mb graphic card computer starts to boot monitor is on dispaly no input signal message or does nothing on its own can there be a problem with monitor or maybe computer case?
    Scholar:
  • 64 Answers
Check the connections on the backside of ur computer.. are the connections inserted properly.. if they are still try to remove and reinsert the connections properly and tighten up the screws properly.. 2) there is a possibility that the graphic card is not seated properly.. so remove the graphic card and reinsert it once again to check that.. 3) still no go then .. remove the graphic card and try to boot computer with onboard graphics.. if the computer boots up there can be a problem with the graphic card.. check compatibility of the graphic card with ur computer.. let me know if this resolves ur issue regards, guru
Posted on May 07, 2010
No input signal
You seem to be talking about the monitor? If you have just added a discrete graphics card ensure that the monitor lead is securely connected. If there is a new card ensure it is fully seated in the card slot, a firm shove may be necessary to ensure that this is the case. If there are multiple connectors try connecting to a different one.
Also, ensure the cable is securely connected to the monitor
Jun 15, 2015 | Computers & Internet
E machine monitor not working. Replaced with newone. same results
There is no communication with the video card. Try re-seating the add-on card or checking BIOS for it to be enabled. You could also try adding a new card, and even testing the monitor on another computer. Lastly make sure the monitor is set to correct input like VGA or HDMI.
Jan 29, 2013 | E-Machines Computers & Internet
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
Computer works fine but No signal on monitor
this may be silly but is your monitor on the right input some monitors have diff inputs for dvi, hdmi . vga make sure unde the options its on the right input and that the cable is plugged in all the way this is an agp graphics card right.
Mar 15, 2011 | HP NVIDIA GeForce4 MX420 (64 MB) Graphic...
VGA connection works, DVI does not
Everything seems perfectly normal...
When you connect the computer to the monitor via an analog VGA cable, you get signal on the analog input.
When you connect them via a DVI cable, you feed the monitor's DIGITAL input, so the monitor doesn't get any signal on it's analog input, and informs you about it.
You have to select the digital input from the monitor's On Screen Menu, and then start the computer up - you should see the picture OK.
Also remember to set the display resolution on your computer to match the optimum (native) resolution of your monitor - this will give you optimum picture quality. In case of VA712B it will be 1280x1024.
Good luck and please come back with a testimonial if helped.
Jan 24, 2010 | XFX GeForce4 Mx440 (64 MB) Graphic Card
Added a ge force 8400 gs pci grfx card to hp a6120n monitor
Alright, let's give this a shot. Your system can handle it as the card only needs 71W of power.
Right-click your desktop and go to properties.
Screenshot.
Afterward select the tab at the top reading, "Settings."
Screenshot.
Now select your new video card in the, "Display" region and choose the device to be your, "Primary Monitor."
Screenshot.
Afterward try plugging the monitor into your new graphics card. It should work just fine.
Feb 03, 2009 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Dvi port not workink
Change monitor input on nvidia control panel and /or change the input on the onscreen display. mine uses the same thing
Dec 27, 2007 | MSI FX5200-TD128LF GeForce FX 5200, (128...
ATI 256MB Radeon X550 Graphics card
r u using dvi or vga? does the monitor support dvi?
Nov 23, 2007 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
Onboard video not working
If you have configured it to be the secondary video adapter in the bios, then it will not work as it has to be set as the primary graphics. the bios will still be looking for your AGP graphics card as the primary and bypass your on board graphics. If you need to use on board graphics, right click the graphics card in properties>hardware>device manager and select dissable or uninstall.
Feb 13, 2007 | Mach Speed VENOM V2DP Motherboard
HP w1907 LCD Monitor Logo
75 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
