Administrator windows vista
How can I bypass the system administrator I am trying to delete programs and it tells me I don't have permission
Thank you
    Guru:
  • 1,049 Answers
The primary administrative user on a non-domain install is the first user created on the machine.
If this account was somehow hidden, there is a backup admin you can access by booting to safe-mode, hit (F5 or F8) on boot before the splash screen loads as (Admin) with the same password as the first account.
Posted on May 05, 2010
You need permission to perform this action
You remove folders by removing the program from the control or settings. Some DLL files are shared by other programs . "Permission may relate to being logged in as administrator or running windows explorer as administrator right click on explorer and check if option to run as administrator" Becareful deleting DLL files as they may be shared
Jun 02, 2015 | Microsoft Windows Vista Ultimate with SP1...
Tip
Software compatibility issues with Windows Vista
ISSUE- Software compatibility issues with Windows Vista
SYMPTOMS-
Fortunately, many applications still work fine under Windows Vista. However, there are some applications which are incompatible with Windows Vista because they are not able to handle the changes in Windows Vista compared to Windows XP. User Account Control is one of those changes to offer a better secured operating system. Sometimes, this problem is solved by (temporarily) disabling User Account Control (which can be done at the item User Accounts in the Control Panel). But for security reasons, deactivating UAC is not advised!
RESOLUTION/ WORKAROUND-
Run as administrator:
Does an application not function properly or does it show an error message every time it is used, try to run it with additional administrator rights! Because most compatibility issues are solved by running an application with additional administrator rights. By default, an application is not started with those additional rights, but this can be done manually by right clicking (the shortcut to) the application and to choose for Run as administrator. Those administrator rights can also be added by default by right clicking the shortcut to the application and to select Properties, tab Shortcut, button Advanced and to activate the option Run as administrator.
Limited permissions:
The issues concerning the limited permissions is related to the problem with the administrator rights. Without the permission to modify files in a certain location, an application is not able to save a file in this folder (as example, it is not possible to change or add files in the C:\Program Files without the permissions to do it). In most cases this problem can be solved by running an application with additional administrator rights. A better alternative is adding permissions to modify the concerning folder. This is done by right clicking the folder and to chose for Properties, tab Security, button Edit (or the button Advanced) and to activate the option Full control for the concerning user account.
Virtual Store: virtualization of files
In Windows Vista, many folders are secured, which makes it impossible for an application to make changes to the files in the folders. For example, the folder C:\Program Files is secured: only an application with additional administrator rights is able to modify the files! However, many older applications continuously try to store files in this folder, which should not be placed there. To solve this issue, Windows Vista uses virtualization of files (which are stored in the Virtual Store). The application is not aware of this virtualization, and thinks the files are stored on the prescribed location. Virtualization is done separately for every user account, the files are stored in C:\Users\loginname\AppData\Local\VirtualStore. Program Files is one of the folders in the Virtual Store, which contains the user specific settings for the applications. All users must change the settings of the virtualized applications separately. This is an advantage as well because the changes won't effect the other users.
DISABLING THE VIRTUALIZATION
Because of the virtualization, files are stored on multiple locations (every user account has it's own virtualization folder), which makes it hard to handle them (the incoming folder of the file sharing software eMule is a good example). If the virtualization is unwanted because the files (and settings) have to be applied to all user accounts? This can be realized by giving all user accounts permissions to fully control all the files in the folder which else will be virtualized. Right click the folder and chose for Properties, tab Security, select Users and set the permissions to Full Control. If this procedure is to much work, the application can be run as administrator as well. This is done automatically by right clicking the shortcut and to chose for Properties, tab Shortcut, button Advanced.
Compatibility issues with older software:
Windows Vista manages some things differently compared to previous Windows editions, which can result in compatibility issues for older software. Some of the compatibility issues are solved by running a program in the Windows XP compatibility mode. This is done with the tab Compatibility of the program shortcut Properties (available by right clicking the shortcut). The compatibility mode pretends the program it is running in an earlier Windows edition. Unfortunately, it is not always a solution to compatibility problems.
TIP: If an older program is still not functioning as it should be, a virtual environment of a previous Windows edition can be a definitive solution to the problem. Here fore, Microsoft's has created the tool Virtual PC (download: www.microsoft.com/windows/virtualpc). This software virtualizes a whole new computer on which a previous Windows version can be installed.
Which applications are compatible?
Although there are compatibility issues, there are many programs which work properly (with or without additional permissions) within Windows Vista. Microsoft investigated many programs and made a list of Windows Vista-compatible software which is devided in two categories: the software is certified for Vista or the software works with Vista. When the software is tested by Microsoft and placed in one of those categories, the vendor is allowed to label the software with the logo Certified for Windows Vista or Works with Windows Vista. The page www.iexbeta.com gives a useful summation of (almost) Windows Vista compatible software. The combination of these sources must be sufficient to tell whether a program will work properly within Windows Vista.
on May 10, 2010 | Computers & Internet
Administrator password to login not working
Microsoft's latest operating system, Windows 7, and its predecessor, Vista, offer a new layer of security that is different from previous releases, such as XP or 2000.
The earlier Windows versions treated all users as system administrators by default. With Windows Vista and 7, all accounts are treated as limited users.
The User Account Control utility provides elevated permissions when required and prompts users for those permissions.
You can control UAC behavior in Windows 7 so it does not prompt you for these permissions.
Start your computer with Windows 7 and log in as you normally would. Your desktop should appear, and any background applications should be closed.
Click the Windows "Start" orb at the lower left corner of your screen.
Click your account picture at the top right of the menu.
You will be presented with a window that allows you to make changes to your user account.
Click the link that says "Change User Account Control Settings."
Look for the User Account Control options slider.
The default option of User Account Control is to notify you only when programs try to make changes to your computer or you install new programs.
The option directly below that does the same thing but does not dim your desktop.
The "Never Notify" option at the bottom of the list eliminates the prompts for permissions.
Move the slider to the bottom of the options window.
Click "OK."
You may be prompted one last time from User Account Control to confirm your settings and reboot your computer.
or
Log in as an Administrator on Windows 7
If you've recently upgraded from Windows XP to Windows 7, you're probably wondering how to log in as an administrator. In Windows XP, the administrator account was clearly visible from the log-on page, but it's no longer there in Windows 7.
Although there is an administrator account, it must first be enabled with the Windows command prompt before you're able to use it. Enabling the administrator account lets you troubleshoot problems with programs on your computer.
Click on the "Start" button, and then type "command" into the search bar.
Right-click "Command Prompt" when the results appear.
Click "Run as Administrator."
The command prompt opens.
Type "net user administrator /active:yes," excluding the quotation marks.
Hit "Enter."
Click "Start," and then click "Switch User." Click the "Administrator" icon to log in.
Aug 04, 2013 | Computers & Internet
Access violation @ address ... in module '...exe.' Read of address ......? I run a medical billing program on Vista Home Pre that has a form template that we fill out, print, and save. When i loaded the...
" Access violation " message comes when something is not present in the software or to tell the software is incomplete to be accessed. This absence brings this message. Try reinstalling. Or try getting a new software. This will definately solve the problem. Thank you.
Sep 03, 2009 | Microsoft Windows Vista Home Premium with...
Cannot delete ESET folder from Program files. the program already uninstalled but left this folder in my Program files folder. error message: "You need permission to perform this action.'' OS - Vista...
Apparently MS in their infinite wisdom decided that in vista they would take the power away from the user and remove the administrator from the equation.
So no matter how many thing your try in the user accounts you will not get full admin rights.
but here is a reg hack that worked for me real well. I am running windows vista home basic
Click Start and Run type in regedit and enter
your now at the registry editor.
click and expand HKEYLOCALMACHINE
go down and click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENTVERSION
click POLICIES
click SYSTEM
you will see the registry entries to the right
right click in the white area and select new DWORD
Name it "EnableLinkedConnections" and enter
Right Click on EnableLinkedConnections and choose MODIFY change the Data Value to "1"
Save and exit Registry Editor
Reboot your computer and try deleting the folder you wanted to again.
WARNING:
Using this reg edit you are changing your registry and could develop problems if you don't do it correctly. Be Warned and do some research prior if you need to understand registry editor.
Jun 04, 2009 | Microsoft Windows XP Professional for PC
I can't open the Lumix Simple Viewer program.
You are probably running Windows Vista, you will need to log in as the administrator on your machine. If you google "How do I become the administrator on my vista system" you will find several solutions to this problem. :)
Nov 26, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
2 operating systems
The Boot Configuration Data (BCD) store contains boot configuration parameters and controls how the operating system is started in Microsoft®Windows Vista.
Remove Windows Vista From Dual Boot System Windows Vista works slightly different from earlier versions of Windows when installed on a dual boot system, in that it has a completely different boot loader.
When Windows Vista is first installed as a dual boot operating system a new boot folder is added to the root directory of your PC. This is a hidden file and therefore is not noticed. When you boot your PC a menu appears with the following options:
  • Earlier versions of Windows
  • Windows Vista
Clicking the Windows Vista option will boot the PC into Windows Vista. If, however, you select the earlier versions of Windows option, another menu will appear from which you can choose Windows XP or whatever earlier version - Windows 2000 or Windows 2003 server - you installed first.
Because of this new boot loader it is not as easy to remove Vista from a dual boot system scenario. Simply deleting the Vista partition will, of course, remove Windows Vista, but, unfortunately, it will not remove the Windows Vista boot loader. For this reason, if you simply delete the Windows Vista partition, on rebooting your machine you will not automatically boot into Windows XP (or an earlier version). Instead you will once again be presented with a menu from which you have to choose which operating system you wish to boot to.
Obviously, once you have removed the boot loader and rebooted the Vista operating system will still be on the partition you originally installed it on. To remove Vista completely you will need to Delete the partition that Windows Vista was installed upon.
To remove this menu, or more to the point, the boot loader, proceed as follows:
1/ Boot the PC to Windows Vista
2/ Ensure you are logged onto the Internet and then download the freeware boot loader utility VistaBootPro (www.vistabootpro.org)
3/ Once you have downloaded VistaBootPro, install it on your machine
4/ During Install VistaBootPro will install an icon on your desktop
5/ Locate the VistaBootPro icon and Right Click on it. Then, from the drop down menu, Click on the Run As Administrator option
6/ User Account Control (UAC) will pop up and ask for permission to run the program
7/ After you have given UAC permission - you must be the administrator or have administrator privileges - VistaBootPro will run.
8/ Once VistaBootPro opens, Click on the Bootloader tab
9/ In the Bootloader Maintenance section, Click on the Radio button next to the option marked 'Uninstall the Vista Bootloader (Used to restore Legacy OS) option' and then Click the Apply button
10/ Finally Reboot your PC
11/ On rebooting your machine you will boot directly into Windows XP (or an earlier operating system). No menu will appear.
12/ All that is left to do now is to delete the partition which originally contained Windows Vista. (Assuming you wish to remove the Vista partition from your hard drive).
Sep 12, 2008 | Acer Aspire 3680 Laptop
Delete folder
Hi muraripcs,
Logon as Administrator and delete the protected folder.
You logon as Administrator like this:
Open the command prompt with Administrative privileges by opening the Start Menu, and typing cmd in the search box, and then press Ctrl+Shift+Enter
Type the following in the command prompt:
Press Enter
Restart your computer and logon as Administrator.
Note: You might want to set a password for the administrator’s account for at least a little protection.
Warning: Running as Administrator in Windows Vista bypasses all security and is NOT recommended.
If you decide to use the Administrator account don’t complain when you start having problems :-).
Regards
Teis
Jul 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
External hard drive
I'm not overly familiar with Vista yet, but I believe that you will have to delete these as administrator. Use the Vista help menu, you'll find it there. If it's a program file you will need to uninstall, versus delete, from the add/remove programs in the control panel.
Jun 24, 2008 | Acer Aspire 5100 Notebook
I'm trying to wtch netflix movis on my Gateway. Whem I try to install the viewer. I get a message that says my administrator won't permit it. I'm the only administrator and user on this GT5432. How can I...
Create a new user account and give it administrator privileges. Use this account to install the viewer.
When OEM (original equipment manufacturers) install Windows - particularly Windows Vista - they often "fudge" the permissions the profile has to let their own programs bypass other restrictions. This can cause unexpected errors with other programs.
May 28, 2008 | Gateway Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
