Question about Denon AVR-485 Receiver
It will cut on and stay on for about 5seconds and then cut off and go back to the standby settings
  • aaahome_auto May 05, 2010
    something shorted out when i was hooking the speakers up when i moved so i opened it up to check the fuses but none where blown
  • 4,472 Answers
First off have you checked all speaker connections on stereo and speaker side to make sure nothing is touching? how about when all speakers are disconnected does it do the same thing? Most likely this is the protection circuitry. How long have you owned this unit? Once I have more information I can assist you further.
Thank you,
Lee
Posted on May 05, 2010
  • Lee A.
    Lee A. May 05, 2010
    Ok, I would check all speaker connections if you haven't already and please read and answer the rest of my questions so I can assist you further.
    Thank you,
    Lee
Tv on standby 5seconds then goes onto mono 5seconds then back to standby does that all day how do i solv this
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ...
Sep 03, 2016 | Televison & Video
Sanyo tv cuts on then right back off
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_17_54_pm.jpgbad caps that are puffed up on top..
Apr 10, 2012 | Sanyo Televison & Video
50 inch samsung wont turn on standby continues to blink
Try unplugging it from the wall for 5 minutes and plug back in .. let me know what happens
Jan 03, 2009 | Samsung DLP HL-P5663W 56" TV
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
TV cut out and stay on standby
hold the power switch in from off for 10 seconds, worked for me.
Jan 06, 2007 | Sony FD Trinitron KV-28FQ75 28" TV
Sound Cutting Out
If you looked for dry connections and found none, there is probably a componet that is intermittant, and these can be tough puppies to troubleshoot, without monitoring the power supply voltages and sittinfg with the unit.
Jan 04, 2007 | Philips LX3000D System
Denon AVR-485 Receiver Logo
54 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
