Question about Dell F3534 Touchpad
Mouse key on laptop
The left mouse key on my Dell 1405e is loose. How can I fix it?
  • 242 Answers
You have to open your laptop.
Read how to here
Posted on Mar 27, 2008
I am having problems with mouse and space bar when
You don't say what program you are using, that doesn't respond, but clicking the left hand mouse key is normal to go to the next page (sideways). The space bar is not normally used for this function.
Sep 14, 2014 | Computers & Internet
How can I fix my Dell Laptop that has a yellow caution, codePCI Bus 8,device 0, function 0
I would remove the battery, etc, and then disassemble the keyboard. I would bet the ribbon cable connection from the keyboard/mouse pad is loose or gummed up. The symptoms are of a poor connection causing 'misfire' of the nerves.... Remove the keyboard, clean the ribbon connector, and re-assemble.
Jul 23, 2014 | Dell Inspiron Computers & Internet
Problem with mouse in my new Dell laptop
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | Dell Inspiron 1420 Laptop
My left mouse button doesn't spring back but still works. It is constantly pressed down. any way to fix?
You may have a broken key, or the keyboard itself may need replacement. Find a reputable laptop technician (any decent mom&pop PC store should be able to help) to remove the key and inspect it.
-Jon
Oct 21, 2009 | Dell Inspiron 1525 Laptop Jet Black
The left mouse key broke loose on my HP Pavilion dv6-1234dx
Easy fix, no. The fix is to replace the palmrest assembly. The required a large amount of dissassembly of the system.
Work around
Use a USB wireless mouse
Oct 10, 2009 | Computers & Internet
The left mouse key broke loose and I cannot see
http://www.disabled-world.com/artman/publish/article_00126.shtml
try your local biglots store, they should have another cheap mouse.
or try a thrift strore
Oct 10, 2009 | HP Computers & Internet
LOOSE LEFT CTRL AND SHIFT KEYS
Generally, the keys on a portable keyboard are non-repairable. The keyboard is a Customer Replaceable Unit (CRU) and if under warranty, Dell should send a replacement, If out of warranty, Ebay is a good source for a keyboard and they generally run about $20
http://cgi.ebay.com/New-DELL-inspiron-Keyboard-630M-640M-E1405-E1505-6400_W0QQitemZ260372955660QQihZ016QQcategoryZ31512QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 23, 2009 | Dell Inspiron E1505 Notebook
Mouse pad buttons not working properly. i have a dell inspiron 6400 and my left mouse button isnt working properly! the right one works fine, please help me!!!
If the left mouse button is not working, then it is most likely the microswitch in the button has failed. To fix, you will need to replace the palmrest assembly
Dec 17, 2008 | Dell Inspiron 6400 Notebook
Left mouse key "broken"/loose
Don't "buy a service manual." These are available from the manufacturer's website. It'll show you how to disassemble the laptop. You can get a cheap touchpad replacement on ebay for cheap.
You could always just switch the left and right touchpad button properties around so the right button is left clicking.
Or you could just get a cheap usb mouse.  You can find them online for less than $10.
Feb 24, 2008 | Computers & Internet
Computers & Internet Logo
124 people viewed this question
Alun Cox
