Question about RCA Televison & Video
I purchased rca 2008. now i need to hook it up.
I purchased rca 2008. now i need to hook it up. i don't have directions for wiring nor controller. i have the converter box to transistion me to digital. model#24v414t
serial #J042DD181
chassis #ATC106
thank you,
brenda.harey@att.net
    Sergeant:
    Champion:
  • 431 Answers
Hook out from conveter box composite video to video input on tv
Posted on May 05, 2010
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
What's your problem?I just purchased a I just purchased a Sharp LC32SV40U. I'm trying to hook it up with my Shaw Direct DSR 505 receiver (DVI to HDMI. I cannot find how to get sound using this
When using this type of adapter you only feed video into the TV/monitor
you have to use a separate set of RCA audio wires to feed the audio into your tv.
Nov 24, 2012 | Sharp Televison & Video
I have this model of Head units. I have used crimp connects to connect the unit harness to the car harness. Hooked up my turn on wires and rca cables. Now my head unit when turned on shorts in and out and...
For starters, I want to make sure. You did purchase a wiring harness that "plugs" into your vehicle, right? If not and you are attempting to hardwire to your vehicle, STOP! You run the risk of frying your entire electrical system. If you purchased a harness you can crip the wires from your head unit to the harness and the harness plugs in. DO NOT crip wires directly. You are experiencing just a little of what can happen. However, if you did purchase the correct harness, you need to check all our crimps again. Hope this helps.
Aug 21, 2011 | Car Audio & Video
Where do i plug in my ipod in the HK AVR65
There is not a direct connection you can use on this receiver, so you option is to purchase an inexpensive adapter that hooks into the headphone jack of you iPod/iPhone/iPad and splits off into an audio/video cable with a red and white RCA connection. Then you may either chose to hook it into the front input or a specific rear input to send the output to the receiver and play music through your receiver. I don't know for sure, but if you are looking to be able to control it via a remote also and potentially gain video output I think there may be an accessory docking station you can connect to your receiver and doc it to. Check the manufacturers website to see if your model supports this accessory.
May 26, 2011 | Audio Players & Recorders
I want to hook up an amp and speakers to my 2008
The remote wire is an accessory power source, like the ACC line from your radio. (usually the red one). Can also be hooked into anything that has 12v when the ignition is on, like a powered antenna.
Jan 05, 2010 | 2008 Dodge Avenger
Trying to hook up amplifier to after market 6by 9 using factory radio
You can not connect the speaker lines directly to the RCA inputs of your amplifier. But you can connect them to your amplifier if your amp has a high level input. Most of the time it looks just like the speaker jacks of the amp, but smaller. It will be labeled high level input or speaker input. Sometimes an amplifier will have a jack for a wiring harness just for this purpose. Some amplifiers have them and some don't.
If your amplifier does not have them, you can purchase a line level adapter at most anyplace that installs car stereos. it converts the speaker level to the proper level of the RCA input.
Just follow the instructions on how to connect it.
If you try to connect the speaker outputs directly to the RCA input of the amplifier you will blow up the pre-amp in your amplifier.
I hope this was helpful to you, if so a good rating is always appreciated.
Thanks and let me know if you need more help.
Jun 20, 2008 | Car Audio & Video
RCA RCU704 Series remote controlTrouble
I just purchased an RCA RCU704 series remote control and I followed all direction for both direct entry and code search.and still cannot seem to program my tv to turn off after repeatedly hitting the on/off button on the remote. What do i do?
Dec 25, 2007 | Televison & Video
Factory stero to amp
If the amplifier has inputs for a high level signal, you unhook the wires going into the speaker and plug them into the amp, then hook the outputs up to the speakers. If the amp only has rca inputs, you need to also buy a line level converter. Then you unhook the speakers, hook the wires up the the converter, then hook the converter up to the amp, then hook the amp up to the speakers.
Please leave good feedback!
Dec 08, 2007 | Blaupunkt PCA250 Car Audio Amplifier
Televison & Video Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
