Question about ASUS P4V8X-MX Motherboard
Hi there I need to fined out if the ram on this board will work with ecc ram or only non-ecc ram.i loast my book for this bain board. thanks
  • Ctrlr4repair
    Ctrlr4repair May 11, 2010
    Please give me the specs for this board so that I may help you that much more.
  • ASUS Master
  • 11,800 Answers
Strictly non-ecc memory.
Posted on May 05, 2010
Got an AsRock P4i65G mobo and bought 2 gig RAM for it. However, I have bought ECC memory by mistake instead of Non-ECC. PC wont boot with the new RAM. Is there any way I can get this to work such as with...
Hi, you can download a manual here:
http://www.asrock.com/mb/overview.asp?model=p4i65g
Your mainboard DOES NOT SUPPORT ECC RAM.
This ram type is ONLY intended for servers
or mainboards that are compatible for that ram type.
This is what your mainboard supports:
Dual Channel DDR memory technology
- 2 x DDR DIMM slots
- Supports DDR400/333/266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
Use only the asrock site when upgrading the bios.
And a bios upgrade does not supports the ecc ram anyway.
Hope this will help you.
Aug 20, 2011 | Asrock P4i65G Motherboard
Would this particular RAM work with my Dell Dimension 2400? http://cgi.ebay.com/KINGSTON-1GB-DDR-PC2700-ECC-REG-KVR333X72RC25-1G-RAM-/380226148054?pt=LH_DefaultDomain_0&hash=item58873e96d6
According to the Dell specification found here:
http://support.euro.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm#1105481
your PC does not support registered ECC RAM.
Most desktop PCs use unbuffered RAM. Registered ECC (Error Checking and Correcting) is a special type of RAM mostly used in servers.
Unbuffered RAM is faster than ECC RAM and is usually cheaper.
To find RAM that is compatible with your PC try the memory configuration tool at www.crucial.com
Please rate my answer is this was helpful.
Many thanks,
Chris
Mar 05, 2011 | Dell Dimension 2400 PC Desktop
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
Can the bios support using ecc memory to run as non ecc?
hi simple answer no, this feature is designed for that specific reason, if you have ECC ram you have to enable the ECC support in the bios, ECC ram has a different timing and ways of using the data flow, it is much slower than non ECC ram and uses more voltage, that's why most people prefer normal SD ram or DDR ram, you can however use these in *********** board if you turn the ECC support off, so long as your board will take the specific ram....hope this helps
Mar 15, 2010 | Compaq Computers & Internet
Can we use non ecc ram in this server. My P100 ECC ram is giving problem. that's why i want to know non ecc ram of P100 or P133 supports this server
Thanks. We have replaced our PC100/REG 64MB/ECC with PC133/ 128MB NON ECC ram. Now my server is working fine for more than 16 hours. We hope we have solved our problem. We have tried with PC100/ 256 MB non ECC ram in this server. It is not working. What i want to know is how much RAM this server supports. there are 2 memory banks are there. In E-Bay , USA this PC100/REG 128MB/ECC is available. Make "MASTER". Can i try that. Pl give suggestion.
Jan 04, 2010 | Acer Altos 330 Server
Hi, does any one knows about which type of RAM is suitable for the mother board MS-7168 VER 1C for the HP PC and whats the max capacity mine has only got a 512mb and i can see it has four ram slots in the...
Here you go....
CPU Support
  • Socket 939
  • Support AMD Sempron, Athlon 64 and Athlon 64FX processors.
  • Support 800 and 1000Mhz HyperTransport (HT) interface speeds.
System Memory
  • Four 184-pin DDR SDRAM DIMM sockets.
  • Serial Presence Detect
  • Support for single-sided or double-sided DIMMs (DDR 333 / DDR400)
  • Support for up to 4 GB system memory
  • Asynchronous HyperTransport and memory controller interface speeds
  • Supports dynamic link width and frequency change
  • Non-ECC RAM (ECC memory will run in non-ECC mode)
  • Single and dual channel mode operation:
    • Single channel mode with single DIMM, non-symmetrical population or non-identical DIMMs
    • Dual channel mode with 2 or 4 identical DIMMs, populated symmetrically
Sirwriter
Nov 14, 2009 | Computers & Internet
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Jul 22, 2009 | Intel Motherboard
Hello! can i use two 1GB DDR2-800 ram in my motherboard INTEL D102GGC2
Your motherboard takes 533 or 400 DDR2 SDRAM Non-ECC DIMMs.
If your memory is DDR2 Non-ECC it will fit but only work at 533.
Jun 17, 2009 | Intel D102GGC2 Motherboard
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Running Non-ECC Ram in a IBM Netfinity 3500 M20
Dear NickB,
In my experience working with many servers, Non-ECC memory will not work on a machine that requires ECC memory. It is possible in some servers to disable the ECC mode in the system BIOS to allow non-ECC memory to work, but you will often end up with performence problems later on.
Hope this information helps, let me know if I can be of any further assistance.
Oct 31, 2007 | IBM Netfinity 3500 M20 8657 Server
ASUS P4V8X-MX Motherboard Logo
43 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
