Question about GE Ovens
I have a GE tru temp oven and it keeps shutting off and the display goes dark all the time it is @ 9 years old.
  • GE Master
  • 8,220 Answers
Must be set for blackout mode. See page 14
Posted on May 05, 2010
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
My GE Profile is about 10 years old. Everything
cheapest attempt would be replacing temp. sensor....other component if still not functioning,would be the main computer board,which can be very pricey
Nov 27, 2009 | GE Ovens
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't completely shut off, gas goes on and off 24/7
The Valve has started to sieze up requires either striping down cleaning and regreasing with polycoat grease or a new valve put on, either solution requires a Corgi registered Gas Engineer. May be expensive could be cheaper to get another oven and have a 12 month guarentee
Jan 20, 2009 | GE Ovens
Ge tru temp
My GE oven was doing about the same thing and i replaced the glow bar and that solved my problem.
Jan 07, 2009 | GE JGRP17 Gas Single Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
262 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
