Question about Insignia NS-DA1G MP3 Player
Jammed Button My down volume button is jammed and I don't know how to get it unstuck. Any ideas on how to get it unjammed?
    Novelist:
  • 170 Answers
Take off the back plate and remove the battery.
Look above the watch-style battery at the volume controls from the inside of the player.
Straighten out a paper clip and press out the buttons from within the battery compartment.
If this doesn't work, the micro-switch is stuck and you'll need to carefully pop it back out. You can see the switch (the very small black plastic tab above the metal housing) and will need to carefully push it back out.
Be careful and good luck.
Posted on Apr 17, 2008
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
I was trying to release jammed paper and the cancel button got stuck. Red and green light on simultaneously,
You will have to pull off the casing to get them unstuck and then replace the casing. Pretty easy to do.
Dec 13, 2015 | Samsung ML-2240 Laser Printer
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
Why does My N2635W goes to full volume at turn on and can not adjust with remote or panel controls?
The volume up button may be jammed in the down position. Try pressing the button to free it. Otherwise it could be a shorted volume up button.
Aug 11, 2014 | ViewSonic Computers & Internet
Commander sunroof
only 2 possibles
1: no power , 12vdc to motor
2: motor bad. (got 12vdc there active)
3: or its jammed.
to tell if its jammed is easy , disconnect the motor drive
then turn the drive end by hand , cant move it? that means the panel
tracks are jammed and the motor can't move it.
so unjam it, by close examinations. of the guides etc.
the FSM has the full instructions on this, why not read the FSM
then ask questions that are not clear there. or?
May 02, 2014 | 2010 Jeep Commander
Acer power button jammed
it seems to be a typical box PC, so I would try removing the side panel then look for some snaps on the front, and unsnap the front plastic bezel from the unit. (one side snaps, the other side is tabbed in with some plastic hinges that will just open as you pull the snaps back). once the plastic is off you should have access to the plastics inside the face panel.
Sep 18, 2012 | Acer Aspire SA20 PC Desktop
Consew Zig Zag CN2053R-1 needle bar is jammed
sometimes when a machine jams, the machine jumps time
taking it to a sewing machine shop to be serviced would be a good idea
Apr 30, 2012 | Sewing Machines
When I press down on the d-pad it goes up when I press up on the d-pad it goes up
It sounds like your up button is jammed. Try cleaning it out with a cloth an something like isopropyl alcohol, or maybe even some dust-off. That should help to unjam it. Hope this helps!
Mar 31, 2011 | Sony Dual Shock 3 Controller for...
I have a hitachi NR 83A2 framing nailer with a jammed firing pin. How do I unjam it? I have the exploded diagram. thx. andrea
by jammed I take it you mean a nail has jammed the driver? If that is the case there is really no easy to unjam it. But unplug the air hose and turn tool upside down and wearing safety glasses and gloves you can try and take a punch smaller than the nose piece and try hitting the driver to unjam nail. If it is another problem please let me know and I will try and help more.. Sometimes we used to have to remove the nose and heat and it goes on but hopefully it is not that bad
Feb 03, 2011 | Hitachi Air Tools & Compressors
My Badger 5, 1/2 Hp, won't operate, even after pressing the "red button." There is power to the unit: when we flip the wall switch the unit hums somewhat loudly. Ideas?
It's jammed. Turn the power off, get your hand in there, and twist the rotor back and forth until it unjams. Hitting the rotor with a big wooden spoon would work, too.
Oct 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
69 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
