Question about Ingersoll Rand 1215Ti 1/4" Titanium Air Ratchet
ON THE SWITH FOR FOWARD AND REVERISE THERE IS A BALL THAT MOVES THE ARM TO THE HEAD TO CHANGE DIRECTION THE BALL BROKE OFF THE LEVER IS THIS REPAIRABLE
How do I change the direction that the arm travels on an Iron Mike Machine?
Iron Mike Pitching machines can be configured for baseball, fast pitch & slow pitch softball.
Aug 30, 2014 | Iron Mike MP-5 Pitching Machine
How to change a Xantia bottom ball joint
Depressurize the hydraulic system. Jack the front and put on jack stands (both left and right side). Remove wheels. Slacken and unscrew the ball joint nut partially. Release ball joint from knuckle using a proper separation tool. Once dislodged, remove ball joint nut and pull out strut/knuckle away from lower arm. You may need to push down the arm with a lever. Remove dust cover from the ball joint. The ball joint can be removed by unscrewing it using a tool that locks into the notches on the sides of the ball joint. Install new one by screwing in the ball joint back into the knuckle.Tighten well.
Sep 01, 2012 | 1998 Citroen Xantia
Light sheilds wont open and lights wont come on. If i turn on my brights and hold the swith the sheilds open and brights come on but i have to hold the switch on.
This could be a bad switch but im not sure what knd of car this is, there are many cars out that you need to push the lever foward to activate the highbeam lights, pulling back is only to turn on until lever is released, try pushing foward that should turn them on and keep them on until you pull back on the lever, good day.
Oct 20, 2011 | Cars & Trucks
How to change driver side control arm
Take the wheel out, undo steering tierod end from hub, undo the bottom ball joint under the hub and lever the control arm down with a lever bar or pry bar and move away the hub from ball joint. You can now undo the control arm from the subframe.
Some models have 3 bolts on the control arm that separates ball joint, you can undo them as well without touching the ball joint. But most of them have rivets instead of bolts.
Dec 27, 2010 | 2000 Mercury Cougar
Stuck in drive
The shifter cable that runs from the lever down to the transmission is most likely broken. You can move the lever on the transmission to put it in park.
May 06, 2010 | 1997 Jeep Grand Cherokee
Stuck in drive, shifter moves freeley, what can be? and how much
there is a linkage that came loose ..shouldnt be much to repair.....you should be able to change the gear to park from under the car...on the transmission theres a lever that moves foward and backwards...just dont do this with the car runnung
Jan 03, 2010 | 1995 Dodge Intrepid
How do I repair the gear shift?
Locate where the shift cable linkage mount to trans, check for good tight attachment to ball socket, then have some one move shift lever through gears watch to see if cable moves shift arm BOTH directions if not replace cable
Dec 24, 2009 | 1991 Volkswagen Jetta
Transmission
Check your rear emergency brakes. A brake shoe pin could have broke and the shoe locks up in 1 direction. but not the other. The other problem you mentioned could happen, but if it is in reverse the trans shifted.
Jun 13, 2009 | 1997 Jeep Grand Cherokee
Changing turn signal switch 1986 lincoln town car.
Get a manual like chiltons or haynes to guide you through this one...Air bag needs to be disabled and yes, wheel needs to be removed.You will need a wheel puller and a tool to remove the steering lock plate. The arm either unscrews from or is screwed to the switch...either way, it's removable.
May 29, 2009 | 1986 Lincoln Town Car
Ingersoll Rand 1215Ti 1/4" Titanium Air Ratchet Logo
70 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
