Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Install a timer to control pool operation
I have an inground pool. On a concrete slab about ten feet to one side of the pool, I have a filter pump (230v), a heater (220v), a booster pump (230v) for a pressure-side vacuum and a pool light (110v). I have an outdoor breaker box next to the concrete slab with three switches, one for the filter pump/heater, one for the booster pump and one for the light.
That breaker box is fed from a main breaker inside my house. I want to install a timer or timers to do the following modes of operation:
Mode 1: Run the filter pump and heater only
Mode 2: Run the filter pump, heater and booster pump
Mode 3: Turn pool light at night either with or without filter pump running.
When the heater runs with the filter, I need the heater to turn off at least 30 minutes before the pump shuts off.
If the booster pump is to run, I need the booster to start after the filter pump has been running and stop before the filter pump shuts off.
I'm thinking a one timer for the light and either one or two timers for Modes 1 and 2.
Is there a one timer that could control pumps, heater and light?
Could I leave the breaker box in place and install a timer between the breaker box and pool components?
Thanks in advance.
Another option would be to get an electronic timer like the Intermatic P1353 that has 3 circuits on it that you could program to cut on and off at different times. For example, you could have one circuit that controls the pump and turns the pump on, then the second circuit would turn on the booster pump at a set time after the filter pump had come on and then the heater could be set to also run at a preset time after the pump circuit was activated. Since the pump, booster and heater are all 220, it's a straight forward hookup with everything in one timer box.
The lights, as stated before, would be on a separate circuit (110) and have its own timer or photosensitive eye set in line.
Posted on May 11, 2010
Testimonial: "I read the P1353ME manual and it has the capability of exactly what I'd like to do. Thanks. "
    Guru:
  • 351 Answers
WOW .. thats a mouth full .. I am thinking that you would be better to use multiple timers.. The outside box and switches seem OK to leave and put the timers after the switches.
the light should be on a separate feed because it is 120 and the rest is 220volts. and that is a simple on/off regardless of the other devices. This could be a simple timer switch like is used for installing in a wall box .. or you could just install a photo eye for the lights to come on dusk to dawn..
I think 3 timers for the pump and the heater, and another for the booster pump .. having the heater cut out first is the tricky part .. thats why the 3 timers .. then you can pre set the delays that you want and eack will come on and go off as you plan.
Thoughts?
Posted on May 05, 2010
My concrete slab is not level what should I do
How out of level is it? 1/8" from side to side, no problem. 2", problem. Spa needs to be pretty close to level.
You could add more concrete on top of slab and level that.
May 21, 2015 | Pool & Spa
Can a person use a hayward de ec40 for either above ground pools or inground pools? if not why?
Yes as long as you are sure to match the flow rate of the pump to the filter. The biggest limit will be the low maximum flow rate the EC40 has. It will clog up to fast if installed on a larger pool...inground pools are generally larger (more gallons of water) than above ground. The pumps are more important to match as far as using inground rated units for inground pools and above ground for inground. Filters only care about flow rate and overall volume of water to keep clean.
John
Feb 22, 2011 | Hayward Pool & Spa
Ray Vac Pool Cleaner for Inground Concrete: Our Ray vac worked well for years but now it tends...
If your automatic pool cleaner is going in circles, you might want to check your backup hydro-timer. If it is releasing most of the water out of the discharge hoke, you might need to replace the defective jet gear assembly. Also, make sure that the transporter jet is not plugged. Check your hose to make sure that there are not any obstructions that would prevent proper movement.
May 18, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac Pool Cleaner for Inground Concrete: after cleaning out debris from my ray vac my jandy...
What model is it? Is it robotic (indepentdent of your pump and filter)? If it is attached to your pump system, it could be the cord getting tangled and causing the pool cleaner to move in circles. You might want to consider running it when you are available to watch it or getting a robotic cleaner that you can set to operate at certain times. You might just need to check the hose for defects that would cause it tangle.
May 17, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
I had a 20X40 inground pool installed on a slope. the pool company had to build up the low side to make it level using the dirt from the hole. the pool looks good but the concrete on the end that had to be...
I think they are using what you did as an excuse to cover their oops, They should stand by their installation and fix it for nill. if the concrete is not standing up to the p[ool , then they did not engineer the installation and make it good for the support of the pool
they drive cars on 6 inches of concrete, and if installed correctly it will last forever
Apr 12, 2010 | Jandy Ray Vac Pool Cleaner for Inground...
Pool in off mode but pump keeps running.
Replace filter pump relay if you have an automated system.if you have a timer it is not wired correctly
Sep 16, 2009 | Sta Rite Sta - Rite 2hp Max - E Pro...
Need to get water of the bottom of the pool
there is a drain hole at the buttom of the deep end. need to clean out the drain before turning on the pump.
May 08, 2009 | Hayward SAND FILTER, PRO SERIES
Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Jandy pool cleaner will not move around pool
First, check your finger screen and energy filter. If they are dirty on these automatic pool cleaners, this can cause the unit to not move. Clean them if necessary. Next, check to make sure that the backup hydro-timer is not releasing most of the water out of the discharge hole. If it is, the unit will not move properly and you will need to replace the defective jet gear assembly. Finally, check to make sure that the transporter jet is not plugged up and that the debris chambe is not full.
Apr 19, 2009 | Jandy Ray Vac Pool Cleaner for Inground...
Ray Vac moving slow, circles deep end, sticks on side of pool
I have the same problem and the best solution is to repair/replace the hydro timer kit. It has inner gears that are plastic and wear down and doesn't rotate through the cycle of water flo that changes it's direction. I'm in the process of exhaustive repair and I'm going to replace the hydro timer - (inside part only) and then see what happens. Moving the gears did change it's moving patterns tho.
Dec 19, 2008 | Jandy Ray Vac Pool Cleaner for Inground...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
367 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
