Question about Dell Dimension 3000 PC Desktop
I can't change boot order Dell Dimension 3000
I've tried F2 and F12 to change the boot order to reinstall XP. All I get is a black screen. Neither work. Someone had installed Vista on a friends system and they want it gone, understandably. I just need to be able to change the boot sequence to CD first. Thanks.
  • thecoffeekin May 05, 2010
    Shoot! This didn't work either. Everytime I hit the Esc key, it looks like it may change to the post or bios but loops back to the Dell screen. I've evn tried popping the battery to reset everything and no dice. I just need to change the boot order. Any help would be appreciated. The pc is a Dimension 3000.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi Thanks for your question
Please try to use "Esc" button to access BIOS.
Good Luck
Posted on May 05, 2010
Dell 8400 Boots to Black Error Screen in XP States to reinstall System 32
This might be caused by hard-drive failure. You should run hard drive test from BIOS to make sure hard drive is ok. You can access BIOS by pressing F2 during start up, from there start hard disk self test and wait for it to complete.
If hard drive is ok after test, insert in your original Windows installation media and reinstall OS.
Oct 02, 2012 | Dell Dimension 8400 PC Desktop
F12 dont show for me to reinstall from cd
turn on your PC, press DEL or F2. find the boot order and set your optical drive as the first boot order. press F10 and then save. This should solve your problem
Jun 13, 2012 | Dell Dimension 3000 PC Desktop
I have a Dell Demision 3000 Series, it shows black screen when I try to reboot it displays adminstrator password required, I had this computer so long I dont know where to get the password.
first unplug all power from your computer. Next open the side panel of the desktop. Inside the computer you will see the motherboard. locate the battery ( round flat like a quarter size, silver color). Carefully ( very carefully) remove it. Wait 10 seconds and reinstalled it. This will reset all your cmos or bios setting to factory setting including deleting your password.
Sep 10, 2017 | Dell Dimension 3000 PC Desktop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
Having a problem with dimension 3000 destop. I turn on the computer and it will proceed to the XP loading screen then the picture will go black and won't return. Using AOC 23inch monitor.
A critical file needed for the launch of XP is missing. To see it can be recovered try to boot in Safe Mode. If you can the reinstall all the drivers and check every program for errors - launch them and see how they behave. If you can't boot in Safe Mode the the only thing left is to reinstall.
Dec 17, 2010 | Dell Dimension 3000 PC Desktop
Step by step procedure to reinstall operating system of dell dimension 3000 . What is the next step to click after I clicked F12? The screen has Boot Device menu. Thanks a lot.
First insert windows disk or recovery disk into cd/dvd rom .
Then when you power up the computer press F1 or F2 or "del" or ALT+F2 key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure Wait for 5 minutes then you can see licence agreement press F8 key for accept then you can see option installing windows press enter if you want to install new windows then select any partition then choose format with NTFS quick then press enter then it format 1 harddrive and copy system files then it restart then simple follow the on screen procedure and enter all info which it ask.If you want to repair previous windows then choose R for "repair previous windows "Then it repair old windows .
Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
Pc keeps rebooting and wont even go to safe mode
the os on the harddrive is not recognising the hardware and could be caused by change in bios settings or bad os.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
Dell Dimension 4600 stalls during boot
Turn the computer's power on.
Immediately put the original Windows XP CD into the drive.
Tell the computer to boot from the CD (not from the hard-drive).
Does it start to boot from the CD?
Do you get as far as the "repair/install" boot-screen?
If so, your basic hardware is OK, and turn your computer off,
rather than choosing "repair" or "install".
Then, it's probably either the hard-drive that is failing,
or the installed copy of Windows XP is fuddle-duddle-ucked up, so that it cannot finish the "Windows startup" processing.
Apr 23, 2009 | Dell Dimension 4600 PC Desktop
Reinstallation CD will not run
When trying to boot from a CD on a Dell system you should put the CD in the CD-ROM tray and reboot the computer. When the initial Dell splash screen appears, you should press F12 (not F2 for BIOS) for a boot menu. In that menu you want to choose the CD-ROM drive. If you have made changes in BIOS you may want to undo them and try this way instead.
Mar 15, 2009 | Dell Computers & Internet
Dell Dimension 3000 PC Desktop Logo
181 people viewed this question
Alun Cox
