Question about Honeywell HFT-114B Super Turbo Table Fan
Our oscillating box fan is now making screechy noises. Currently I am putting it on high to get it going for a bit, then I can bring it back down to low. I figure it's just dropping some WD40 or cleaning it from the inside, but the screws used are not standard and I can not get the fan open. Any suggestions?
  • 4,102 Answers
Hi, if you go to a car spares shop you should be able to buy a cheap accessory screwdriver kit that should have the correct adapter you need to undo the screws,
but as for using wd40 i wouldnt go that route as wd40 is an easing spray and not a lubrication, it would stop the noise for few days but then it would make it worse as the wd40 would dry up any grease or oil that is their, instead use some spray lube you can also buy this from a car spares shop or you could use something like machine oil or petrolium jelly to grease it up with this will then stop the noise and it should also work a bit better as it will be able to turn a bit easier
Posted on May 05, 2010
Oscillating table fan makes banging noise when rotating
mcdevito75 here, Sounds like that oscillating swtich is either a little loose or could use a drop or 2 of 3 in 1 oil. Try to twist offf the oscillating swatch button and see if you can tighten it or put a drop of oil on it.
Jul 24, 2010 | Holmes Products Holmes HASF1304S-UC 12",...
Will not oscillate
mcdevito75 here, You say Box fan, are you sure this fan is suppose to oscilate?? if so the Oscilation feature shuld be in 1 of the fans switches.
Jul 19, 2010 | Dayton (1UM39) Floor / Box Fan
Hi. We have a screechy noise coming from front,
I raised the right-hand end of the long component with rotating vanes in it by wedging a piece of folded floor vinyl under it . I assume that this has put renewed tension onto the drive belt at the other end. Now I am seeking a new part in order to make a permanent repair.
Oct 01, 2009 | Refrigerators
Noisy table fan - Vornado silver swan
the electric motor bearings and/or brushes have worn. soft metal screws is an indication of the quality of the motor.not good. sometimes units are of nice design, look and high price but they throw in a cheap chineese motor. all you can do is put a few drops of oil on the motor bearings, its ok to do when this worn out
Jul 30, 2009 | Vornado Silver Swan Table Fan
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
My oscillating fan has stopped oscillating how can i fix this
pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Jun 30, 2009 | Black & Decker BDTF1010B Tower Fan
Sealed subwoofer box with two 10" jl audio subs hooked up to jl audio 250/1
you mite have the gain to high turn it down a bit just because there's a max gain doesn't mean you need to use it . you mite have to turn the bass boost up. you should get a bit better sound out of it
Dec 12, 2007 | Jl Audio 250/1 Car Audio Amplifier
Fan makes clicking noise when oscillating
inside the motor there is a nylon gear that is broken. the oscillation operates off a gear connected to the motor drive.
Aug 27, 2007 | WeatherWorks CH-1850SFW Riviera Stand...
Honeywell HFT-114B Super Turbo Table Fan Logo
322 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
Tom Chichester
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
