Computers & Internet Logo
Posted on May 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bettery can't charge
My laptop is fujitsu semens amilo pi1505 .last time my charger spoil so i can't charge my laptop long time (5 months) now i buy a new charger but now my laptop battery can't charge. so pls give me solution .
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 91 Answers
  • Posted on May 05, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
91
Questions
0
Helped
15093
Points
257
You may have the wrong type of charge, your port where your charge cord go in may be loose or not connected correctly anymore.
You also may want to check into buying a new battery for that laptop. Depending on how old it is it may of died after alot of use.
I'd test it using those two ideas first. If that doesnt work contact the maker of the laptop.
2answers
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
1helpful
Hot laptop and battery charger
It may well be that the battery that's being charged is getting past its sell by date. They only last for so many charges. easy way to find out is remove the battery, connect the power supply, and if the charger power supply doesn't get hot (usual to get warm) then its your battery. It is perfectly okay to use the laptop without the battery installed on the mains.
2helpful
Rechargeable battery cannot be charged despite continous plug in of AC cord of charger
Battery is probably dead. Will need to purchase new one, not repairable. When replacing, do not buy "new" battery that has been sitting around on a shelf for several years. Will have much shorter life. Insist on battery that has been made within the last year, maybe 18 months at most. Expect to pay $50 to $125. To increase battery life, try not the let them fully discharge when using. Most recommendations are keeping them above 10% charge.
I need a "G" key for the following laptop: fujitsu amilo li 2727
lol search on google it help alot i have fujitsu semens i get what ever i want for google.com i got my drivers form google.com i resreach in google.com
2helpful
Fujitsu siemens amilo m1405 won't switch on
hi i have fujitsu sieman amilo 3710 it will no switch on there nothing no noise no light but when put it on charge the little charging light comes on to say its charging can u help
3helpful
Win xp sp 2 and fujitsu siemens amilo pro v2030
here is the link for driver download it otherwise i will try another driver if it doesnt work with SP2 ok
http://webdownload.fujitsu-siemens.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=F8D86EE3-5A24-4F8B-9FBC-3BA22CD6B7F2&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FSC_GemtekWMIB160GW_3100641_1003614.ZIP&FileSize=29309648&From=VXZ0Z2NvSGtuZ1ZxRHRxeXVndCAo
pls consider rating me FIXYA if i helped u
Laptop chargers
Probably you damaged the motherboard with an incompatible charger, You are very likely to need to have it replaced and to buy a fujitsu spare charger or at least an aftermarket compatible one...the charger might have broke instead because of overheating caused by the higher load, but cannot be sure about it because you didn't post full specs.
Laptop Will not load past the windows loading screen
BOOT UP INTO SAFE MODE AND LET WINDOWS TO TRY AND FIX IF YOU DO NOT DO THIS THEN YOU ARE GOING DESTROY THE MASTER BOOOT SECTOR ON THE HARD DRIVE AND THAN YOU HAVE TO PAY SOME ONE LINKE ME TO REBUILD THE MASTER BOOT RECORD, UNLESS YOU MAY HAVE ALREADY DONE
CANDYMANGANDY
Fujitsu AMILO Pro V2035 PC Notebook
If it's only 10 months old it is still within the manufacturers warranty, so do not touch or alter anything to do with the charger or battery, as even though the battery is seeming to be the fault, it is normally the motherboard charging point that is faulty or the motherboard not recognising the battery is connected.
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
