Question about Symbol PDT 8146 Portable Terminal
PDT8146 T4BA40WW I have a pdt 8146 (PDT8146 T4BA40WW) which I'm trying to load but the unit say No Power Micro!!. When I try load the power micro and partition table nothing happens. Is there a special way to load the Power Micro? The unit has IPL V1.14.2074.
Troubleshooting generators
If this unit dies under load conditions, decrease your load and try it again.
If this happens under no-load conditions, check your fuel supply. Start with the filters, then check pressure and flow.
Jul 21, 2014 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Want to remove U3 software and completely wipe SanDisk Cruzer Micro flash drive.
Try using a tool like Rufus to format the drive to its full capacity. There are links on the page to other usb utils.
Feb 07, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Charging a Symbol 8146 scanners
No, not necessary. Let me know if you need any help related to Barcoding equipment. . You can always contact me directly or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Jan 15, 2010 | Symbol PDT 8146 Portable Terminal
PDT8146 question I want to take out the radio card on my PDT8146 and run it in batch mode like an PDT8100 how can I do this? Will taking the radio card out do it or do I need to turn off software setting...
Yes, taking the radio out will make the unit batch. There is no sofware switch to tell the scanner, you need to reflash it with Batch Platform Hex file. Let me know what Operating System you have and which Processor. XScale or Strong Arm and I can get you the right files. I can provide steps necessary for this request. You can always contact me directly or 630-622-2024 toll free 866-271-9891 Ask for Andrew
Jan 06, 2010 | Symbol PDT 8146 Portable Terminal
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Cruzer will not light up or open when installed
Jul 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
NO scan beam
do u get a red dot?
if u do there might me something stuck in the scanner.
Mar 17, 2008 | Symbol PDT 8146 Portable Terminal
Zen 6Gig Micro gone completely dead
take battery out, this works best if you have an ac charger,
but turn the on/off switch to on and plug the unit in keep plugging it in and out till it turns on this may only work for ac chargers.
Dec 05, 2007 | Creative Labs Zen Micro MP3 Player
Partition to USB flash drive
I dont think that will be possible as the memory in these units have the operating system on the internal memory. You would have to format the drive and use disk management to do so. But it would render the unit useless.
Sep 17, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Symbol PDT 8146 Portable Terminal Logo
253 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
