Question about Canon PC-1060 Black and White Copier
Hello, we have a Canoncopier pc1060 with a paper jam. We need to be able to get the top off to remove the jam. we thought we got it all out from the side but we can hear a piece of paper in there when the rollers are on. Thanks
  • Canon Expert
  • 1,326 Answers
I'm not sure if you mean the adf or the top half of the copier??? The adf comes off, it's tricky, there are pins that hold it in. As for the top part of the copier, why would you? I did it only once, will never do it again. I think you problem is in the fuser unit. If so, it comes out of the left side by the exit tray. Before I go any further, have you seen any small pieces of thin blackish grey plastic. If so, you need a new fuser unit or fusing film. I would not go any further if that is the problem. Without it to put right back in, you will forget how to put it back in... Good Luck
Posted on May 06, 2010
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
Hello, I have a canon pixma printer iP1500 and it has been working fine until yesterday. I keep getting a paper jam message but no paper is stuck. Then the paper will go in off sided and the paper does...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 30, 2010 | Canon Office Equipment & Supplies
Hp deskjet 6940 paper jam light blinking every time i try to print. no paper jammed, have opened and closed all doors, turned the wheels as the other help indicators say, but still it will not print. ...
This past Saturday we just had a similiar problem on our church HP printer. Different number than yours, but most likely the same solution. It jammed when the last person used it, so they removed the crinkled paper. Or so they thought - there was a piece maybe 1-1/2" triangular shape stuck on top. I liked to never found it, I looked even with a flashlight 4 times before I caught just a hint of white way up there. If that is not it, there could be a door you have not opened. Most of them open top, back, front. Ours also opens on the side. The back opens in two places. Occasionally there can be a piece of paper you can only see from one door.
Dec 14, 2017 | HP Deskjet 6940 InkJet Printer
How to remove the scanner unit on Canon PC1060
you sould not have to remove the scanner unit to clear a jam in the fuser
open all doors and remove anything marked green
remove the the cartridge assembly if it will come out
open the fuser section (usually a release that takes pressure off of the fuser rollers
remove the paper feed cartridge
you now should be able to follow the paper feed path from the time paper goes i until it comes out
if you are not sure of path take a piece of card stock and simulate it goig through feed ara
there are small microswitches/ poto eyes that sense paper lok for an small pieces also clean thes poto eyes with q tip and rubbign alcohol
reassemble
unlug from the wall then plug back in and turn on p roblem sould be solved
Jan 05, 2009 | Canon PC1061 Copier
Paper jam
make sure that the exit sensor is realese down.generaly u ca check the sensors not to have pull out
Nov 11, 2008 | Canon Office Equipment & Supplies
PC1060 canon copier
in your case you have to remove the fuser
I will try to guide you, most of the models are the same.
1-turn off machine and unplug
2-open the side door, you already know where the paper is it's most likely rolled up on a hot long roller, this is the fuser unit
3-with a phillips scredriver(star) remove 2-4 screws that hold the unit, it will have a plug most likely on the right hand side unplug
4-unit should slide out (unless there is a cover holding it
5- you can now see and work on the unit turning the gear by hand to remove the paper.
6-reverse the steps
Aug 12, 2008 | Office Equipment & Supplies
Canon PC1060
The fuser comes out the left side, not from the top of the copier.
Jun 20, 2008 | Canon PC1061 Copier
Canoncopier jammed
I need more info in order to help you with this problem. Does it power up? Is it showing a jam? Is there an error code displayed?
Apr 16, 2007 | Canon ImageClass D880 Copier
Canon PC-1060 Black and White Copier Logo
263 people viewed this question
old marine
old marine
