Question about Acer Aspire 5630 Notebook
Losing ip address when unplugging network cable
We use a specific ip address at work, when i disconnect the cable leave for the day, and return to work and plug cable in i need to reenter the ip, submask, etc?
    Guru:
  • 1,481 Answers
Pls check with your network admin guy why you are losing the data once you unplug....
may be that's how it's suposed to work....due to security reasons...i am just making a guess.....
when i was working in GE Atlanta even we had the same method...this is to prevent anyone from making his PC a web server....our laptop's IP address will change once every 10 days....
so check with your admin guy...pls
reg
Posted on May 05, 2010
Connect network wireless
If you are using this as ethernet adapter, there definitely are IP addresses for each cable plugged into the router. Your MAC needs an IP address for the router to ROUTE the traffic to and from the internet. That's what Routers DO. Listen to your Support. Unplug all other devices from the router you connect to, then connect your adapter, and let the router assign an IP address to it. Then connect the rest of the devices one at a time, and see if that works. Make sure you plug the cable from the efibre to port #1 on the router, for highest priority of traffic.
Sep 13, 2013 | EMC LightPulse LP11000-E Fibre Channel...
I have a asus wl-600g. i sometimes do a power off, and power on again. two days ago, i did a power off, and i kept it disconnected, since the morning until the afternoon. When i connected it again a few...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | ASUS WL-600g Wireless Router
I just received a new modem from my cable company and now my router doesn't work. I tried resetting it and it still doesn't work. What do I do next
Sep 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
Printer communication error
check the network cable... disconnect the network cable and ping the copier... if you can get the copier IP address to respond... then you have an IP conflict... if you plug the network cable back in... turn the copier off and on and still cann't print from any pc... then reset the copier... if you still cannt print from any pc then you need to try changing the IP address... and try again... still doesn't work... change the network cable and try again... still doesn't work... plug a laptop into the network cable and ping the laptop... if the laptop works... the print card is bad...
Dec 12, 2009 | Canon imageRUNNER 7200 Copier
I have a Gestetner 2212 here at the office and it kept getting jammed up. the copier guy came yesterday and "fixed" it by cleaning the photoconductor unit. It worked great for a few hours, but now it won't...
yes... either the network cable got unplugged from teh copier or you have an ip conflict... here is how to tell... if you have an ip confilict... unplug the network cable from your pc... print a network status page or go into the print driver and pull the ip address from it and then, on your pc, press start, accessories, command prompt and then type ping and type in copier's ip address then press enter... it should look like this ping 192.168.168.168 if you don't get four time outs... then you have an ip conflict and you need to change the ip address of the copier to one thats not in your ip range... generally thats a low ip address...something that ends in a number less than 100
Dec 09, 2009 | Gestetner 2212 Digital Imaging System...
My wireless adapter TEW-444UB disconnects from network if computer stays "on" for a day or so. It's connecting again if I unplugged and plugged it again. This drives me crazy. Is it a way it designed and...
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. ypur connection won`t drop after this.
Jul 13, 2009 | Trendware TRENDnet TEW-444UB 108Mbps...
Dell inspiron E1505 cannot connect to internet
A hardware error usualy indicated a bad network cable or a bad network card. Have you tried using a different Cable?
Mar 04, 2009 | Dell Inspiron 1501 Notebook
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
HP C6100 Wireless printer has stopped working
The HP C6100 series has had some ip setting issues. One day my printer didn't print. I checked the ip settings on the printer and got some 648.154.1.654 address. I had no clue where this ip number came from, because my router's ip is 192.168.0.1. I went into the settings of my printer and set my ip settings manual. Then I went into the router settings and reserved the ip setting I previously setting on the printer to the printers MAC address. I also set static ip address for each computer on my network. This network response issue started about one year after I purchased the printer. I still lose connection every once in a while, but rebooting the router reconnects the printer and everything sitting in the que to print starts to print. To stablize the issue: upgrade router firmware, set static ip address on your network devices, reserve those ip address in your router, , if all else fails reboot router.
Jan 23, 2008 | HP Photosmart C6100 All-In-One Printer
Acer Aspire 5630 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
