Question about Astar LTV-2701 27 in. HD-Ready LCD Television
Pwer supply board repairs
Is this board the same as the one in the Akai lct2662/2715? The Akai part number is E7802-004002. Have been told it was made by Megmeet in China. What is the cost to repair? thanks
    Top Expert:
  • Astar Master
  • 14,553 Answers
This model uses 2 different boards--both are not available from Akai (SAMSUNG) look carefully at all the filter caps on the power board--many will be bulged up at the top---last one I did had 20 bad caps---space allowing--replace with higher voltage rated caps---8 were 2200 mfd @25 volt, 4 were 3300 @ 35 volt, 7, 1000 mfd @ 10 volt, and one 1000 @ 6.3 volt---- Sets with 10 digit serial number use one board and sets with 8 digit serial number use another board---I have seen "rebuilt boards" on several sites on the internet for about $115 + S&H---which is about what the original board replacement sold for when they were available.
Posted on Mar 02, 2009
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
Akai lct2715 power supply repair needed. Please respond. Failure appears to have occured over several days. First picture had distortion at edges. Then blue AKAI screen would light but picture was not in...
I very highly doubt that is merely a power supply problem,I would suspect that it is a small signal board (aka scaler board) or at the very least,have the inverter boards checked
Jul 16, 2009 | Akai LCT2715 27 in. LCD Television
Need a description and location of or a schematic for Megmeet MLT198K. Optionally a new power supply. I have not been able to get a response from AKAI. This blew EC10 (1000uf/16v) an electrolytic which I...
There are 2 1000uf/16v caps that blow on the board. The second one is under the heat sink nearest the one that is easily seen on the board. You might also have to replace the 220uf/25v caps under the heat sink as well.
Jun 21, 2009 | Akai LCT3201AD 32 in. LCD Television
With no picture but only sound on my Akai PDP 4294
Try replacing the Y-sustain board. Might have to replace buffers attached to it too. Have you had it diagnosed? My picture went out and I replaced the power supply board. Worked for 2 weeks then acted up again. Got a different power supply board. Same thing 2 weeks later. Was told it now was a bad Y-sustain board. Replaced y-sustain board. Worked OK for about 2 hours then started having picture issues. Not the same issues before power supply or y-sustain problem. Was told that you might have to replace buffers attached to y-sustain when you replace y-sustain. Tired of dealing with it and only watch a couple hours a day, so I don't always have the problem unless I watch the TV for a long time. Will eventually replace buffers to see if that works. I would definitely find a place that gives free estimates or close to free to get a technician diagnosis. Then you can decide if you are able to do the work yourself.
Jun 06, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Flashing red lite..black screen
You have a defective power supply or another of the the processing board ... depends on the number of flashes ... please take to agent for complete diagnosis and repair
May 12, 2009 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Will not come on
Loook at power supply board. Chances are you will see two to seven capacitors with the top slightly puffed. Replace all capacitors you see like that and your TV should pwer up again.
Mar 13, 2009 | iLO LCT32HA36 Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I'm looking for a power supply for a AKAI LCT37Z6TA
I bougt this PS on eBay for $85-13S/H. Something wrong with my TV but supply is OK Markmaya
Oct 23, 2008 | Akai LCT4216 42 in. LCD Television
Akai 4290 power board
Yes, I'm sure the board is bad. I had the TV checked out by a local TV repair shop. I also opened the thing up to see if I could do anything with it and it's obvious that this is the board that has bitten the dust. The correct number for the board is AA98-00188A. I made a typo in the first post.
Jul 30, 2008 | Akai PDP4290 42 in. EDTV-Ready Plasma...
Astar LTV-2701 27 in. HD-Ready LCD Television Logo
230 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
