Question about Sharp EL-1197P Calculator
I have the Sharp EL-1197PIII adding machine and I am not understandings how the settings are currently set. I want it set for just basic arithmetic. However, it is adding in a way I do not understand. Please help before I resort to buying a new one! Marisa
  • marisag327 May 05, 2010
    I have tried that option and have been unsuccessful.
  • marisag327 May 06, 2010
    I have already tried using the reset button and that does not help my problem.
    Brigadier General:
  • 7,191 Answers
Your problem dated May 5 2010 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks for using FixYa
Posted on Aug 09, 2010
  • 713 Answers
Hi,i think you have mistakenly distorted the basic arithmetic settings,by hitting an undesired button,however,this will solve the problem;
Press the clear key on the keyboard for 5 secs,if this doesn't work,unplug the machine from the power supply,and plugg it back after 5 mins,or remove the battery if it has one and re-inser it back after 5 mins. This is a master reset and should restore the basic arithmetic setting back to your adding machine.
Thanks and good luck
Posted on May 06, 2010
  • Oyelade Gbenga May 06, 2010
    please unplugg the machine and plugg it back after 5 mins.this ought to solve the problem
  • Oyelade Gbenga May 10, 2010
    i hope your problem is solved.as expected,
  • 17,970 Answers
Hi Marisa:
I suggest RESET the device; check your User Guide section about Operation Controls (when you open the document, apply "zoom+" for read).
Hope this help.
Posted on May 05, 2010
  • ZJ Limited
    ZJ Limited May 05, 2010
    You need un pluged the device from power to RESET; any positive result have with this action? Its so rare; after this "reset" any past set option is stored in there. Just have the factory settings, and now any user can modified this to you task work.
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
HOW DO I SET THE DECIMAL ON SHARP EL-1197PIII?
Up Arrow: Answer is rounded up
5/4 key: Answer is rounded off
Down arrow: Answer is rounded down
The decimal will float if the calculation is multiplication or division
If the decimal selector is set to F then the answer is always rounded down
Aug 26, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Setting up the Date & Clock after reset
Follow the instructions on the first page of this manual.
Apr 05, 2013 | Sharp EL-1197PIII Calculator
How do you put paper in sharp el-1197pIII adding machine?
Follow the illustrated instructions on the first page of this manual.
Jan 11, 2011 | Sharp EL-1197P Calculator
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
HOW DO I CHANGE THE DATE AND TIME?
Only the EL-1197PIII has time and date settings, so I assume you own this model. A link to the manual is here: http://www.sharpusa.com/~/media/96B576A9DADF49A0B1321B57CAB1741D.ashx
You can find the time and date set up process on the first page, 3rd column, 2nd paragraph, under the headline GRAND TOTAL/RATE SETTING MODE SELECTOR.
Feb 11, 2010 | Sharp EL-1197P Calculator
Setting the time and date
To set the date, make sure that you are in Rate Set. type in the date such as August 3, 2010 would be entered as 08.03.2010 then press the date time key. This will set the date. To set the time type in the time such as 4:20 PM would be entered as 16.20 then press the date time key and this will set the time.
Feb 02, 2010 | Sharp EL-1197PIII Calculator
Setting correct date
You may download a copy of the manual here. The clock setting instructions are in the middle of the first page.
Sep 02, 2009 | Sharp EL-1197PIII Calculator
Sharp EL-1197P Calculator Logo
167 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
