Question about Hotpoint Aquarius WF000 Front Load Washer
My hotpoint wf 000 will wash but wont rinse or spin any suggestions please
    Genius:
  • Hotpoint Master
  • 1,474 Answers
You need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear....
Posted on May 05, 2010
Well we had this problem before, we called an engeneir after few days and when the mashine worked properly, he told us that the programing ofthe mashine could sometimes freak out, so give it a few days and try again...
Posted on Sep 05, 2010
Wf 860 shows tap and h2o on display
It seems to indicate that the inlet flow is low and so trips over from rinsing. check the INLET valve filter and the free flow, remove the inlet line and check the flow, if this is good then remove the line after the inlet and check for a good flow when the machine is put to start. If this is low then check for DIRT on the filter of the valve. You can also try and reverse flush to clean the valve. Connect after there is a good flow , This must solve the issue.
Jan 15, 2013 | Hotpoint Washing Machines
Washer won't agitate it does spin the clothes
Hi
If Washing machine wont agitate there are several reasons that causes such problem,please check the bellow link to troubleshoot your issue:-
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help#itdoesntagitate
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | Hotpoint VWSR4150B Top Load Washer
Hi. i have had funny noises during last couple of washes. now washer wont drain programs are responding fine but washer keeps filling up and not draining.water backed up and came out of the drawer hotpoint...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF865
i have a wf 860p hotpoint washing machine and it has come up with an error code of f 08 can you tell what this error is and how i can fix it.
many thanks
lynette
Oct 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Does not spin and rinse properly
Sounds like motor is not coming up to spin speed. May be overheating, in which case you would need a new motor.
Feb 16, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
500 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
