Acer Aspire 5500 5570-2609 Laptop Logo
Anonymous Posted on May 05, 2010
CPU Coolin Fan
My Acer Aspire 5515 cooling fan stop working right after the computer bootup. Do I need to replace the mainboard? Please let me know if you have any idea of what is causing this problem.
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on May 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
Helped
7375
Points
16
The problem is from the power source recognizing the fan.If you don't have a specialist to find the wrong piece,replace the motherboard.
Testimonial: "Very realistic advice"
2helpful
Cpu fan stopped working
According to the specs, you have an Intel i7 CPU in a socket LGA 1366. You need a fan compatible with that socket and rated for that CPU. The fan has an electrical connector to the mainboard that must be unplugged, then there are four spring-loaded locking screws that must be undone to lift the fan off the CPU. The replacement fan, if new, should already have thermal transfer compound on it. Be careful not to mess that up. Before installing the new fan, clean all old thermal paste residue from the processor cover. Do not use anything other than a clean lint-free cloth for this. Install the new fan, oriented so that the electrical connector can reach the mainboard plugin. Lock down the four screws, ensuring that the fan is centered over the CPU and has full flat contact to the CPU cover. It is not a difficult process, but can be a bit scary for first timers. Be very careful not to let the screwdriver slip when pressing down. It could strike other mainboard components and damage the board. ALWAYS DO THIS KIND OF WORK WITH THE UNIT POWERED OFF AND UNPLUGGED.
1helpful
Acer aspire g7710 cpu fan stopped working
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
2answers
Cooler fan
Lots of local places can provide a decent price and even install this for you, however based on the model number provided I was able to find this:
http://www.laptopcpufan.net/acer-aspire-5741g-series-laptop-cpu-fan-lf.html
As well as http://www.pchub.com
1helpful
How iclean my acer laptop cooling fan acer aspire 5734z
ur enternal fan may be not working chek ur cpu fan
1helpful
My fan stopped working in my Acer Aspire 5515....how do I fix this?
Hi there, 1st of all ilike to know that is your laptop working or not? if its working & only fan is not working then, remove the back cover in your laptop, then remove the fan .Dont forget to disconnect the fan first from motherboard. After that replace it with new fan. Thanks& waiting for your feedback.
2answers
Shutsdown without notice could it be the fan mor fans not working
This is typical of a overheating (thermal shut down) CPU problem.
When the CPU overheats and shuts down, it won't bootup again until the CPU cools down. If this is not fixed then the CPU will fail.
This problem is caused by either a faulty fan or the fan and heat assembly is clogged with dust.
Check the fan to see if it spins freely, replace if faulty and clean the dust off the fan and heatsink assembly.
Also apply fresh thermal paste to the heatsink/CPU.
1helpful
The CPU Fan stop after the pc boots
The fan will only run when needed to cool the computer. Fans normally run at full speed during bootup, but turn to low speed or off after bootup if not needed. Is your computer running hot enough that the fan SHOULD be running?
2answers
Big problems
start the system hit delete or F2 to enter setup load system defaults then exit saving changes.
if it didnt work
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
