Question about Whirlpool Dryers
Whirlpool Gas Dryer I need the wiring diagram of Whirlpool WGD 5000
    President:
  • 949 Answers
Here is a link to your diagram, Whirlpool prints both gas and electric models on the same page, since yours is gas use the bottom diagram.
Let me know if you have questions.
Tech_Sheet_01_20_2010/Wiring%20Sheet%20-%20W10185979.pdf
Posted on May 05, 2010
Need a wiring diagram for a whirlpool gas dryer model ggq8811lwo
If you open the control panel heading there should be a wiring diagram and a tech sheet inside. In some rare occasions these sheets may be inside the cavity of the dryer.
Jun 20, 2012 | Whirlpool Dryers
Hi, I have a WED8300SWO and I am unable to get heat now from the dryer...any ideas?
Well it might be the element. The basic innards look like this:
Take the top off first then remove the control panel then the electronics and then the front comes off. Unplug it before you start.You should also look for reasons why the dryer stopped heating like lint blocking airflow. Clean that up and check each of the safety's for continuity. I like to remove at least one wire from each component to prevent ghosting or false read.
Check the heater element the same way. The model is a wed so that means it is electric. wgd would be the gas model.
How to get into it video and service manual
Sep 01, 2011 | Whirlpool WED8300S Dryer
Have a WGD 9400 SW Gas dryer. there seems to be very little heat in the drying process which is now taking forever. Any ideas.
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not improve, you may have a defective heat coils.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool gas dryer Model wgd 5300 sq0 worked fine yesterday, dried some comforters and bedding. Today there is no heat, I don't think it is a lint problem, any ideas would be appreciated>
your glow rod,may be defective..this is like a pilot lite for the gas
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Dryers
I have a whirlpool gas dryer lgq9857lwo. The
There is a flame sensor on the burner, it is probably the problem. It can get dirty(wipe the windo on it). Also with the drum out you have short circuted the air flow. Clean the inside as lint burns to well and is hazardous. The dryer may be equiped with a one time high limit switch, protection in case of over heating, it may need to be replaced. The thermo disc (thermostat-s coul be bad) Check all components with a multimeter. Ust the wireing diagram usually inside the control head, as a guide. GoodLuck. If this was helpfull, Please leave Positive Feedback. Thanks, SnugglePants
Oct 21, 2009 | Whirlpool LGQ9857L Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
No heat in gas dryer
hey it dose not have a pilot your dryer has an ignitor.if you have a volt meter with the ignitor exposed you need to check voltage to the ignitor.if voltage replace ignitor,if no voltage re place thermal fuse you can see how the electricty travels by looking at thr wiring diagram
Dec 31, 2008 | Whirlpool LGR8648 Gas Dryer
Brand new dryer
try holding door switch down with your finger while pressing start button.if dryer starts then your door needs adjusting.
May 20, 2007 | Whirlpool GGW9200L Gas Dryer
Dryers Logo
252 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
