Question about Video Game Consoles & Games
Ps3 help on my ps3 when i try to do a system updat 2.20 its coming up part way through with an error ? help me ?
    Problem Solver:
  • 15 Answers
Are you wireless? if so connect an ethernet cable cause your download may be getting interupted.with a wired connection this wont happen
Posted on Mar 26, 2008
The playstation 3 does not work with certain games saying there is an error on the router (error code: 80710723) How can we open more ports on the router? Thanks for your help
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
Jan 04, 2011 | Belkin N1 Vision Wireless-N Wireless...
PS3 problem
Is it trying to download an update? If so, try downloading the update from the sony site on a pc and save it to a usb stick in a folder called UPDATE (has to be capitals) which should be in a folder called PS£ (deatils of this are on the sony site).
Then turn on the PS3 in safe mode by holding down the start button until you hear three beeps and go to option 6, system update and follow the onscreen instructions. Just this minute done this on my sons PS3
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 comes up with an error when i am trying to do the new update for FIFA 10. Comes up with error 8002ae22... can someone help in normal people terms on how to fix this
If you receive an 800 series error code on the PLAYSTATION 3 system, we recommend performing the following steps which may correct the problem.
Install the Latest System Software Update
To check what version of the System Software is currently installed on your PLAYSTATION 3, from the PS3 Home Menu go to Settings > [System Settings] > [System Information]. The system will display the System Software version number. You can check online to make sure you have the latest version installed.
Restore Default Settings
From the PS3 Home Menu, go to Settings > [System Settings] > [Restore Default Settings]. Once you select Restore Default Settings, you will see a list of settings that will be restored. Scroll through them and press the X button to restore the settings. After the operation is complete, you will see the initial set-up screen that appeared the first time you turned on the PLAYSTATION 3 system. You will need to go through the initial set-up process before you can use the PLAYSTATION 3 system.
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
PS3 Update successful,install failed,systemrebooted,error8002F14E
On the playstation 3 site error code tool says this code is an issue updating the PS3 sytem software. Try to start with the hard drive uninstalled then try again installed. If that dont help i would format the hard drive in a laptop and see if it helps. worst casr scenario you could dissasemble the PS3 and unplug tha battery on the main board and see if that helps. Good Luck
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
Ps3 error 80710723
could be corrupted file, try to download again..copy to a pendrive correctly formated..put the update file and try to update again..good luck..try with another pendrive...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
When i try to do system update 2.80
its something to do with sony? dont worry its not the system its one of their errors with the software. I've talked to like 10 friends. same **** is goin on. I would wait awhile to try.
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
Keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 80 GB - Error Code 8002991
Hi tomdonnatim,
If your PS3 is brand new, you most likely have to update the system's software to a more current version in order to properly play many Blu-Ray discs.
In order to update your PS3 system:
Go to the home menu, move to the "Settings" tab (the 2nd tab from the far left), scroll down to "System Update". It takes about 5 minutes to download and fully download the update, but it should solve the problem.
More information on the system update can be found below:
http://www.us.playstation.com/ps3/about/systemupdate
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
