Question about Zenith C27A24T 27" TV
How to put tv in tv/video to watch dvd no remote
No remote need to put tv in video mode
    Sergeant:
    Champion:
  • 431 Answers
Push cannel down,below channel 2 will be video inputs
Posted on May 05, 2010
Benimur
  • 6966 Answers
SOURCE: SWITCHING FROM TV MODE TO VIDEO MODE
Hi, If the AV button is not in your remote, then perhaps it is part of the Ch up/down buttons - meaning right after your last programmed Channel would be AV before the first program Channel. Although I have yet to come across such a case, I have worked on units/remotes that have this feature of the AV included in the channel memory. Good luck and kind regards.
Posted on Aug 20, 2007
  • 7 Answers
SOURCE: lost remote
Fairly easy and resourceful fix for this. Spent the past hour on the net looking, and no one had any info. So, we post here!
Our remote was lost, and were in the same unable to use the input port situation on our Durabrand BH1304D. Tried 3 universal remotes with no luck. However--- we are back in business now, Houston!
My fix-- grab a DirectTV remote (we had a white one-- RC 32 is the model). It's compatible with this 13" Durabrand TV, and most people a neighbor probably have one!
To program it to the TV (at least in our case), you have to slide the top switch to TV, then hold and press MUTE and SELECT until the green light flashes twice under the TV switch. Then press numbers 11034 and the light should flash twice again. Ta-da! Should be in business. We were!
The input button also worked as is, no need for the other step listed in the remote manual. But if your TV is changing channels and volume, but no input button, quick easy fix there too apparently. Didn't have to use it, but the input button can be activated or deactivated as needed. Simply hld SELECT and MUTE down again, the hit 960 on the keypad. That should be the activate/deactivate code per the manual.
Hope this helps someone, as the durabrand remote situation stinks, but thanks to the power of internet and users like us, there's now a solution in your reach! :)
Steve
karaokestl.com
Posted on Feb 02, 2008
SOURCE: help on changing from tv to video mode
try codes 0154 or 0159
Posted on Aug 12, 2008
SOURCE: TVS2740B, how do I switch from TV to Video Input manually?
going to have to get a universal remote with input button on it, or tv/vcr button, had same problem!!
Posted on Jan 04, 2009
SOURCE: I'm not able to put
Hi, well ALL TV's can be controlled from the Buttons ON the actual TV itself, look carefully on the TV, you will find a set of buttons, usually about 7. They should be marked, ON/OFF, CH UP, DOWN, MENU, ENTER/OK/SELECT, VOL UP/DOWN. Now Multiple presses will access differing features on the set, usually after pressing the ON/OFF button, you press the menu button and select your Input, Tuner, external, etc, once set, you Change the channel with the UP/DOWN key, and the Volume with the -,+ Key.
It's all in the user manual in the download link below.
http://www.devicemanuals.com/guide/Television/Sylvania/Sylvania-6420FB-20-TV-User-Guide-TmpJek9UZz.html
Posted on Sep 09, 2010
How do I go from TV mode to the DVD screen with my remote
My TV remote has a 'TV/Video' button that when pressed, toggles the TV's screen back n' forth between watching TV or viewing your DVD/VHS. Pressing the button once displays a video-1 screen, twice, a video-2 screen, and third, back to watching TV programs (having two video option screens allows for another DVD or VHS player to be assessed, as long as the TV has another rear connection for a second unit). As long as the DVD player is plugged into the back of the TV, the TV's remote (not the DVD's remote) should accomplish the function.
Nov 11, 2016 | Televison & Video
I just purchased this DVD LG I'm trying to find out what channel to put it on to watch my DVDs on and I'm on DirecTV
There is usually a switch on the back of the DVD player to choose either channel 3 or 4. You will need to use the TV's remote not the direct TV remote. To change the source or input to the correct inpit mode on the remote select input then select the input mode that you plugged your DVD into ( tie. HDMI 1 or 2 ) then turn on DVD that should do it
Jul 26, 2015 | LG Televison & Video
What chanel do i put tv on to watch dvd movies
You are trying to work out how to watch a DVD movie on your TV
The DVD should be connected to your TV with Audio Video cables.
And it will most likely be connected to AV1 on your TV
The easiest way to find out would be to
  • Put a DVD in the Player and press play
  • Now the TV is probably in channel mode, so find the button on the TV remote that says TV/AV
  • now press this button TV/AV and it will scroll from TV channel to AV1, AV2 etc until you see the DVD picture.
I hope this helps you.
If so please leave a vote or comment.
Have a great day
MobileJB
Jul 18, 2011 | GPX D1816 DVD Player
How do I record onto a DVD from a video camera
connect camera to dvd on the dvd were you connected into will have (e.g EXT or AV 1-2 or 3 printed on it) you should put dvd on to that input mode by pressing input/saurce on remote then put tv on the input mode you watch dvd on
to record press on remote
Dec 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
No video signal
You need To cut The Wire and Put Them Again In ur DVD or Num
Apr 15, 2009 | Philips 32PT6441/37 32" TV
Jan 04, 2009 | Sansui TVS2750 27"
No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Sep 13, 2008 | Symphonic ST420FF 20" TV
Can't watch dvds with my dvd player
Try two different things 1) on some of these tv's you could try pressing 00 to see if it will put you in input mode or 2) with your remote you should be able to push the input or tv/video to go to the input selection . In both of the above make sure you push the tv button first then step 1 or 2 . Good luck
Mar 07, 2008 | Proscan PS27108 TV
Zenith C27A24T 27" TV Logo
272 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
