Question about Delta Enterprise Astor 5-in-1 4860 Crib
Stabilizer bar broken
One of the ends to the stabilizer bar broke off. What can I do?
Need to convert to toddler bed.
  • 340 Answers
Hello! This is Products America. We supply crib hardware for many different manufacturers. According to our information, that model is under a recall if the date falls between 1/95-12/00. You may go to the www.cpsc.gov website to read about the recall. We do not carry conversion rails. Delta's contact number is 800-377-3777. I hope that we helped you with your crib hardware needs. Should you have any further questions, please feel free to contact us at 800-205-9642 or 800-772-1041. We are open M-F 8 am-6 pm CST. Products America
Posted on May 06, 2010
Hyundai 2004 2.7 l ratting noise coming from undrneath
have the front end checked for broken suspension arm bushes , stabilizer bar joints and bushes
broken exhaust flexible section
check for exhaust loose , cat converter failure or rocks under the heat shields of the exhaust
Jun 26, 2017 | Hyundai Cars & Trucks
Tip
How To Install Replace Broken Sway Stabilizer Bar End Link Lincoln Town Car...
<span style="font-weight: bold;">How To Install Repair Replace Broken Sway Stabilizer Bar End Link Lincoln Town Car 98-02 1AAuto.com<utube src="8mkGPCQ-jTM"></span>
on May 20, 2011 | Lincoln Town Car Cars & Trucks
What happens if your rear stabilizer bar breaks on my 2002 Kia spectra?
the stabilizer bar is to help with cornering and heavy wind gusts to keep the vehicle from the feel of floating. it is not a huge problem but can lead to one depending where it broke, if its just the link pins easy and cheap fix. but if the bar its self is broken if can possibly hit suspension or brake lines so check the movement of it
Apr 07, 2015 | Kia Cars & Trucks
How to change shaft stabalizer bar on 2002 buick rendezvous
The stabilizer bard rarely need replaced. There 2 brackets holding the bar in place. They both have a bushing that goes bad from time to time. The real issue with the stabilizer bar is the end- the stabilizer rods on the ends. You can usually replace these in about 1/2 hour and the job is done. Go to your local parts store and order the stabilizer rod and bushing kit, The kit will come with an in instruction sheet, and it is a very simple job.
Dec 31, 2014 | 2002 Buick Rendezvous
How do i replace a stabilizer bar on a 1996 Ford f150 my stabilizer bar broke
If it's the actual stabilizer bar....remove both stabilizer end links at the top and both frame mounts (4 bolts), remove old stabilizer bar and replace.
Dec 08, 2014 | 1996 Ford F150 Regular Cab
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Where to purchase Stabilizer Bars for Delta Luv Crib #4750-6?
What is wrong with the stabilizer bars that came with the crib? If they broke or fell apart, you should report that to the CPSC as it could be a safety issue.
Jan 12, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Delta Enterprise Astor 5-in-1 4860 Crib Logo
192 people viewed this question
Top Delta Enterprise Baby Gear Experts
Dorel UK
Dorel UK
Are you a Delta Enterprise Baby Gear Expert? Answer questions, earn points and help others
