Back to:
Tags:
Eiki LC-SB20 Projector Multimedia Projector
Black and white projection
posted by laprofe on Mar 26, 2008
i have an eiki projector with a computer and an elmo connected to it. the elmo projects in color but the computer does not.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 27, 2008
Not Rated (0)
Marrie
Rank:Wiz Wiz
Rating: 84%, 275 votes
Hi there
First try another cable from the PC to the Projector.
The VGA / RGB Cable used from your PC to the Projector has a couple of very thin copper wires on the inside and they easily get damaged.
If this doesn't help then you should try another PC.
If that works then you'll know that it is the PC's card that is faulty.
If it doesn't work you'll have to get the Mainboard repaired or replaced , because the inputs on the Projector lies within the Mainboard.
Must warn you that a Mainboard replacement is a bit on the expensive side.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on black and white projection:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
Could you explain to me how to connect a infocus machine...
The projector still displays from computer if is through...
my projection tv keeps turning off
lost remote unit is on control panel lock can i manualy...
Projector comes on shows blue screen, but when I try to...
Loading problems.
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
