Question about Adcom GTP-860
PROBLEM WITH GTP-860 VIDEO COMPONENT 2 NOISE ON
PROBLEM WITH GTP-860 VIDEO COMPONENT 2 NOISE ON PICTURE WE ADD CAPACITOR WE HAVE SAME PROBLEM
  • Todd Hill
    Todd Hill May 05, 2010
    where was the cap installed why? and what value?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 848 Answers
PROBLEM WITH GTP-860 VIDEO COMPONENT 2 NOISE ON PICTURE WE ADD CAPACITOR WE HAVE SAME PROBLEM?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
AI 0100B Lien Chang 860 ALZ GJ712D EH Power Supply Backlight Inverter
Posted on Mar 22, 2015
  • 55 Answers
Maybe its a noise cause by other appliances inside your house
Posted on May 06, 2010
TV suddenly lost picture. I have replaced 5 capacitors and a fuse that were obviously blown. However the power light is on but no picture. How should I proceed. Any suggestions welcome
You have changed certain components , have you tested all the circuits with a multi tester?
If the fix of obviously damaged components has not fixed the fault you will need to do more extensive testing.
See links below
http://www.bing.com/videos/search?q=clicking+noise+from+pcb+capacitors&FORM=VIRE1#view=detail&mid=961405D9314BD86E8C2B961405D9314BD86E8C2B
https://www.youtube.com/watch?v=0Z_T_cS_B7g
Jun 22, 2015 | Televison & Video
What's needed to install a logitech v--uap42 p/n:860-000056 pid:Lz719bp camara
You need software to utilize the camera. Go to Logitech's web site to get it.
Aug 28, 2014 | Logitech V-uap42 860-000056 Lz736b6...
Samsung Model 860 LCD TV. Just 2 years old. Screen went black but sound still works. Seems like others are having the same problem.
If the screen is black and stays black, no sign of life at all, you may have one of many tv's with faulty capacitors on the Power Supply Board. Capacitors are responsible for distributing specific amounts of power to a tv's components. That would explain why you have sound but no picture. Most likely, capacitors that send power to the screen have failed.
You have a few options. The first and most obvious is to have it fixed by a pro. The second would be to replace the faulty PSB. The third option would be to replace individual capacitors.
Good luck
Let me know if I can help further.
Kaufman605
Feb 14, 2011 | Samsung Televison & Video
How to hook up yprpb
This is another way of describing Component Video (Y usually a green colored connection, Pr usually color coded red, Pb usually blue). The device you want to hook up to the Emerson must have a component output.
The YPrPb needs three cables and does the video (picture). You will still need 2 cables for the audio (sound) and the they will be a white and red normally. Don't mix up the red for the video with the red for the audio. If you do, the right speaker will have noise and the picture will be bad or gone. If so, switch them so the are correct and you should be fine.
Component video can handle HD.
Jan 19, 2011 | Emerson LC320EM9 32 in. LCD HDTV
27" (diagonal screen) Panasonic regular crt TV few years old, no serial # on front and too heavy for me to look at back. Picture comes on great, then a grey (NOT BLACK) screen covers 99% of screen with a...
It will be good to check the capacitor on the +B voltage that goes to the power section in the main board. A filter capacitor of about 47mF/160 V can be defective.
Next check the capacitor on the HT line to the grid-22mf/250V replace.
If possible loop on capacitors in the horizontal section particulary the IC.
Now the tip I can offer:
If the fault occurs on heating shcek out htis area to confirm and isolate the component.
But finally I understand that when you press any key the picture is good.If so check the memory IC/cmos IC in this section for logic control, it might be having a switching fault, a conflict or the video noise is coming on in default but goes off in the data selection mode. Do a soldering around this section on the IC , capacitor and see if the fault goes off or becomes irregular when this section is heated, if so there is a semiconductor producing this noise error .
So start from the begining so that we have a clean voltage inside.
I hope my advice helps.
Aug 22, 2010 | Panasonic CT-27G14 27" TV
Recently, after about an hour of play, when my Adcom GTP-760 is warm, a low level hum begins and can be heard on all channels regardles of the source selected. The hum cannot be heard when the unit is...
The filter capacitors are probably going bad is the likely cause.
It may also be bypass capacitor in the preamp section.
Noting whether the hum volume varies with the setting of the volume control would aid troubleshooters.
One might be able to isolate the bad component with freeze mist/circuit cooler.
Apr 21, 2010 | Adcom GTP-760 Amplifier
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
No power with 700P LCD monitor, No green light, nothing. replaced 2 popped 470 25C caps. Nothing else looks bad. Board 860-ALZ-M713-F
You will need to check for any pico fuses that run along those capacitor lines they may be marked as pf or nf on the pcb
Jan 03, 2010 | Mag Innovision LT776s 17" LCD Monitor
Component Video Inputs/Outputs Not Behaving as advertised
I have had this problem in the Field with a Client. I had fixed it by going into the ADCOM menu and Resetting ALL of the Inputs and output for the Devices. You have to select everything you need, then exit out of the Menu, SHUT OFF the ADCOM, WAIT about 10 secs, then turn it back on. Or Else it Does Not SAVE Properly! Weird. If you can not see the Menu on the TV Screen then try to hook up a Composite (Yellow) cable from the ADCOM to the TV and select the TV input to make the Changes. I really hope this helps out it sounds like an Evasive problem which is hard not being in front of the Equipment!
Nov 29, 2008 | Adcom GTP-860II
Gateway C51GU01 MOTHERBOARD (no video)
I supose you should test the capasitors one by one.
Faulty capacitors :
http://www.asti-usa.com/support/appnotes/65/2.jpg
if the capacitors arent flat they are possibly bad note in the picture the blue / black capacitors are flat. the black orange capacitors all seem bad. the two are bad for sure.
Apr 04, 2008 | Foxconn 865A01-PE-6EKRS Motherboard
Open Questions:
See all Adcom GTP-860 Questions
Adcom GTP-860 Logo
133 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
David Burbee
David Burbee
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
