Question about Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair
Scooter motor clicks.
I have a Electric Mobility explorer. The battery says full, but when pull forward/reverse lever just clicks. The click appears to be comming from the electric motor at the rear base. Thanks
  • 23 Answers
This sounds like you have tripped your circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead. Do you know where the circuit breaker is on your model?......
OK this one was hard:) I like a challenge. I have located the User manual for your chair, it does have a circuit breaker, the troubleshooting page even mentions it, but NOWHERE in the whole document does it give its location. Can you beleive that? I have tried other models in your brand, and similar products but none of them show where it is. The best I can find is this link to an online tech manual on maintaining your model. if you scroll down to page 66 it gives a rather indistinct photograph but I hope it helps.
http://www.scribd.com/doc/15487491/OnLine-Technical-Training-Course-Roadrunner-Mobility-Corporate-Office-717#fullscreen:on
If you need a copy of your User Manual Follow this link. Troubleshooting is on Page 27. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/invacare/Invacare%20Pronto%20M41%20Owner%27s%20Manual.pdf
Posted on May 06, 2010
The clicking noise you are hearing is the brakes releasing. This is normal operation for scooters or electric wheelchairs. If you move the joystick and the vehicle doesn't move you may be in "free wheel" mode. Located on your scooter or EWC are motor release handles. Check to make sure that these are not in "free wheel". Basically what these levers do is disengage the motor from the transmission if there is a failure of some kind and the vehicle needs moved.
I'm guessing that there is not a circuit breaker problem. If there was the entire unit wouldn't even turn on. All scooters and EWC's have some sort of protection but not all have circuit breakers. The ones that do have breakers have them located on the back where the joystick harness plugs in or in front down by where your calfs would be. Look for a little white button with a 50 or 70 on it. To reset it you push it in. Sometimes these fail and can't be reset and will need to be replaced. If a scooter or EWC does not have a breaker it will have a fuse of some sort mounted inline with the batteries. These will range from 50 to 70 amps and are either a large automotive type fuse or one mounted directly to the battery. If either fail they will need replaced.
My experience puts the money on the fact that your chair is in "free wheel".
Posted on Jun 16, 2010
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Mobility scooter - Electrics work, but won't go
hi, they are a nice scooter so let's get it working ,
First check that the freewheel lever is disengaged, in drive mode.
Do you hear a click when pressing the lever to go forward or backwards?
What can happen is the brake located on the side of the motor can seize,,,
Please keep me updated
Regards
Jan 04, 2013 | Electric Mobility Mobility Electric Power...
Scooter won't reverse and makes clicking sound by the controller by the electric motor
There is a servo which switches the transmission from forward to reverse and it needs replaced.
murf427
Aug 01, 2012 | Electric Mobility Health & Beauty
Rascal scooter no forward or reverse or seat rise
Does the scooter have any power to it at all? Have you recently charged the batteries? If the scooter has been sitting unused for a while the batteries may not take a full charge and need to be replaced. If the batteries are good, check the fuses and all of the battery connections to ensure nothing has come lose. Sounds like a power issue.
Oct 17, 2010 | Electric Mobility Mobility Electric Power...
Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Jun 27, 2010 | Electric Mobility 3 Wheel Motorized...
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
No movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Apr 24, 2009 | Health & Beauty
Electric Mobility Invacare Pronto M41 Electric Scooter Power Wheelchair Logo
520 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
