Question about Olympus DS-2 Digital Voice Recorder
Recorder Locked My recorder is locked and will not record. When I go to the menu under "lock" it reads "Read Only Memory." How can I turn the lock off?
  • 1 more comment
  • buddy54 Apr 15, 2008
    Thanks, Marigringota!! I appreciate your help!!
  • mkgingold Aug 26, 2008
    Suddenly, one day to the next, I received the sae message!!
  • edouglasww Apr 20, 2009
    My recorder was hooked up to my computer for a few days and all of a sudden, all of my recording are gone and then I get the same issue when I detach it from the computer "Read ONly" and there's a lock. I use a Mac.
The same problem "Read memory only". The best solution is : submenu/format/start
Good Luck
Posted on Jun 09, 2008
I had the same problem and found a solution on this site, under a different problem. If you go into the submenu and go to "Format" it will erase and reformat your memory. Mine is all fixed now. Just make sure your files are all saved because they'll all be erased. Good luck!
Posted on Apr 11, 2008
The solution above worked. Thanks, Folks
Posted on Jun 08, 2013
Same problem and same solution. I suspect that when I delete the files off the mounted ds-2 disk when I connect to my computer, the memory read gets locked. But this format solution works.
Posted on Dec 07, 2009
Formatting corrected the problem. But why did it occur? I had recently erased all the files on my DS-2, after transferring them to my Mac. Anyone else experience this sequence?
Posted on Nov 10, 2008
I have been trying to find a solution to this problem and had all but given up. Thank you Marigringota. Yahooo.
Posted on Jul 29, 2008
Function locked
You may have a SD card with a lock switch in the lock position. If not, the internal sensor that detects the position of that switch may be bad. It could also be corrupted memory so try reformatting the memory from the menu. Scroll thru the menu until you see the memory icon.
Dec 18, 2013 | Philips Pocket Memo 9360 Handheld Digital...
Hi, All Folders are locked and if you try to record its says READ ONLY CARD? I have 1 sound file on the card which i need. It won't play on the computer system either?
The memory has been corrupted. You will need to reformat the memory from the menu in order to use that memory card again. This will erase all files.
If you need to recover the file, download a free recovery program called pc inspector smart recovery, from http://www.snapfiles.com/get/smartrecovery.html
Jun 23, 2011 | Olympus DS-2300 Digital Voice Recorder
The Olympus DS-330 read only memory lock
You may need to format the recorder to clean the file system on the recorder. Follow the directions below to format: If you format the recorder, all function settings will return to their defaults*. All files** stored in the recorder will be deleted. If you have important files that you want to save, connect the recorder to a computer and transfer those files from the recorder to the computer before formatting the device. * Date and time settings won't be cleared, so you won't need to set them again. ** Locked files will also be deleted. 1 Press and hold the FOLDER/MENU button for 1 second or longer. The menu opens. 2 Press the up or down arrows button to choose "FORMAT". 3 Press the REC/SET button again. 4 Press the FF or REW to choose "START". 5 Press the REC/SET button. Formatting starts. "FORMAT DONE" displays when formatting ends.
Jun 11, 2009 | Olympus DS-330 Digital Voice Recorder
Olympus DM-10,locked in a "Read Only" mode
The recorder should be formatted only by using the internal FORMAT function found in the recorder’s Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended.
Apr 10, 2009 | Olympus DM-10 Digital Voice Recorder
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DM-20 erase lock is on, how to undo it?
The voice recorder is in read only status - you will need to format the device to remove the lock (read only). Go to menu - to submenu and then run the format option. make sure all files have been downloaded as once device is formatted all files will be permanently deleted
Oct 16, 2008 | Olympus DM-20 Digital Voice Recorder
Can't unlock my locked digital recorder
format the recorder through the menu and this will erase all the files
Sep 25, 2008 | Olympus WS-100 Digital Voice Recorder
DS-400 DIGITAL VOICE RECORDER
went on the "menu" option and formated the disk. I first downloaded the files I needed to my computer. Took off the "lock" option.
Jun 25, 2008 | Olympus DM-20 Digital Voice Recorder
Locked file ?
The folder lock can oly be solved by chosing the option "format" in the sub-menu. But please copy the *.dss - files still resting at your card at your harddisk first.
When the recorder finishes the format procedure, all folders will be unlocked again.
The "Read-Only-Failure" will occur again at recorders with differend user profiles, when you put the switched-off recorder into the docking station first and switch the power button to "on". So avoid this constellation!
Jun 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Had same problem. Found online handbook for DS-4000 and page 37 pointed way.
Press menu button on the handset.Go to sub menu. Page 37 of online handbook suggests you can lock and unlock from this but I used the format icon on the submenu to reformat the card. Seems to be working fine now.
Feb 14, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus DS-2 Digital Voice Recorder Logo
456 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
