Question about RCA RS2047 Shelf System
RCA RS2047 has CD in slot 3 jammed in play bay. will not eject despite pushing all the buttons and cycling unit on and off. Is there a manual override?
  • 55 Answers
You have to open it manually
Posted on May 06, 2010
2004 Ford F150 rear entertainment system will not eject dvd, will play the dvd and will run when eject button pushed but will not eject the dvd any ideas on how to get the unit to eject the dvd?
The unit is connected by small set of gears that push tray /disc out. As tray comes out it either pushes disc out of slot or pops open door (depending on which style of face you have). If you have kids I would not be surprised if something is caught in between disc and face or jamming edge of door. (know this from own experience). The face of player can usually be carefully popped off by gently prying at corners. If you get face off you may be able to see if something is stuck in unit that does not belong, or see if a piece is broken loose near face. If unit has door that opens you can try using a slim but stiff piece of plastic and keep tension on door with plastic while hitting eject button. On some units there is a small hole on face that is manual release that ejects disc - even if no power. Usually takes a long straight push in hole (straightened paper clip or dental pick) and it manually pushes gear set to go out. So many of these units are different but most do have a manual release. Check owners manual to see if it shows a picture of face and possible release hole. Have had kids fight over changing a disc and pushed in on it while it was ejecting so it stripped gears, and had kid hang on ceiling mount unit that tore screen totally off. I feel your pain....
Jan 21, 2015 | 2004 Ford F150
Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Jun 12, 2009 | Bose Wave Music System CD Shelf System
I have a 2004 Ford Explorer Limited which has a 6 cd player. I do not have satellite service. A couple of days ago, I pulled into my driveway and turned off the ignition. After the engine cut off, the CD...
If it's a remotely installed CD changer (not in-dash) you've got a pretty good chance of getting it operational again. You need to pull the unit out of the vehicle and take the cover off of it. #1 phillips screws 6 or 7 pop the top and look down at the loading mechanism, chances are it tried to eject a cd int an occupied slot and jammed. Gently slide the cd back towards the player side so it's out of the cartridge, leave the top off and plug it back into the truck. it should automatically reset itself. If this is sucessful, eject the cartridge and inspect the slots, if they are warped or bent, replace it with a new one. If you have a Laser Lens Cleaner that uses fluid, use it. If not, get one, they can be purchased at almost any retailer for 15-20 and will extend the life of the lens quite a bit. Run it thru 3 or 4 times a year, it only takes a minute. If your unit is an in dash changer... It's kinda the same process, but alot more work. The unit has to be pulled out of the dash, which takes a little time, then it has to be disassembled, if your not a nuts n bolts kinda guy/gal, let a car audio shop do it for you. If you need more help, post a comment and I'll help some more. Hope this helps
Jun 11, 2009 | Car Audio & Video
Error 3 comes on display when I press disc button to play a cd. cd will not play, cds will not eject
It's one of two things; more than likely the cartridge is jammed, meaning it tried to return a cd in a slot where there already was a cd stored and has jammed half way. The way to confirm this is to open the slider door to the cartridge, use a good flashlight, and try to see if a CD is "half in- half out" of the transport. Don't force the CD into the cartridge or transport. What you have to do is pull the unit out of the car, take out the screws on the sides and top if any and take the top off the player. Now you can see exactly whats wrong. if there is not a CD in the transport, gently push the cd into the player, freeing it from the cartridge. Now plug the unit back in with the top off and watch the mechanics, it will automatically reset itself. once this is done, eject the cartridge and carefully look at it for bends or warps, if you find any, replace the cartridge before you use it again. They just get warped over time and vehicle heat and is a very common problem. Hope this helps
Jun 07, 2009 | Car Audio & Video
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
There is a CD jammed in the cd player. (6 cd changer) It is a 2004 Ford Escape
It happens to me all the time on my 2002. Try cycling the load and unload buttons for the stuck CD location. If that doesn't work try ejecting the CD. When the slot door opens, try putting another CD into the slot and push on the edge of the stuck CD.
Jul 27, 2008 | 2002 Ford Escape
Blaupunkt IDC-A09 5-Disc CD... Problem:
Ok guys thius it how it works.
Blaupunkt supply a repair kit for this unit, this basically is a fix. but only works for 8 out of 10units.
its a pain to fit too.
you have to replace the 3 spindle guides and arms. the part number is : 8619001490 there a reall complicated thing to fit.
i am looking to get a install guide sorted. and will soon be selling the kits on my website
www.carradiospares.co.uk
Regards
Mark
Blue ICE
Jan 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
THE IDC-A09 CAN BE REMOVED BY INSERTING THE STANDARD PHILIPS REMOVAL KEYS INTO THE TWO HOLES EACH SIDE OF THE UNIT AND FORCING THEM OUTWARDS SLIGHTLY AND THEN THE UNIT SHOULD SLIDE FORWARD
Dec 03, 2007 | Blaupunkt IDC-A09 5-Disc CD Changer
Won't Play CDs
hi make sure that you cart is inserted all the way in, push the eject button why hitting the mag with the handle of ascrew driver. this may dislodge the jammed arm/lever. otherwise its down to your repair agent.
regards
Mark
Oct 08, 2007 | Alpine CHM-S620 6-Disc CD Changer
RCA RS2047 Shelf System Logo
85 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
