Question about Microsoft Xbox 360 Console
Help me how did u solve your problem because my xbox 360 display wont appear on the screen all i get is the sound for the normal start up menu.
  • 121 Answers
Turn your console off unplug the audio/video cable from back of xbox and plug it back in. make sure the white cord is in the hole of your tv and make sure the yellow one is in the yellow on the t.v. (unless your hd). make sure the cables are not loose. and on the plug in the back of your xbox for the audio/video cables is a switch that says hdtv and tv make sure its set to whatever your hooking up.
Posted on Mar 28, 2008
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
My xbox 360 turns the middle green light on when i start it up , the nothing happens the console wont start up and no display appears on TV and Controller wont sync. with my xbox
  • Your Xbox may have "Red-ringed" a while ago without you knowing. This means it overheated due to lack of ventilation. In order to get it fixed, you will have to send in your Xbox via the support site at xbox.com.
  • Please reply if you have any more questions. Good Luck!
Jul 07, 2011 | Microsoft Xbox 360 Console
My xbox 360 says im connected to xbox live checked network setings and it says xb ox live is up and running...however when i try to play need for speed online..it says xbox live not working functionally?...
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings." Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.) Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP. Save your settings and verify the network is functional. On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live. On the Xbox 360, use the "Test Xbox Live Connection" option instead.
If you need more help post back! Thumbs and testimonial are welcome!
Jan 15, 2011 | Computers & Internet
Cant connect Xbox 360 to this wireless router
Jan 15, 2011 | Linksys WRT160N Wireless Router
Xbox 360 wont operate
Hi
This is an issue with the GPU and leadfree solder. When the console gets hot and beleive me they get very hot, the solder overheats and fractures are created. The unit if still in warranty will need to go back to microsoft or if out of warranty or no luck with them, the system will need to have the GPU normally reballed which is a specialised topic.
Depending on how long you have had the unit, it may be worth investing in the newer unit that actually has a slightly better cooling method than the original ones.
The famous X-clamp tirck might work but it wont last long and you will be back to square one.
Hope this helps
Thanks
Taz
Oct 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Xbox 360 Fault
Does the light in the power brick is red, orange or green when you turn on the xbox?
Oct 02, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Jun 05, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
