Question about Dewalt Tools & Hardware - Others
I have a dw734 planer and need to see a manual on how to reset the screws for leveling the cutter heads
  • 2,100 Answers
Do you have the blade set gauge that came with the planer? It is a little metal thing that looks like a bottle opener with 3 feet on it? Anyway, you need one, you can buy one at the Dewalt web site or where you got the planer. What it does is set the knives all to the same depth, every time, you can't miss. It rides on the drum, with the blades on the leveling screws, and a wrench in one of them, the jib in place, just snug, not tight, you lift each end of the knife up to just touch the gauge, then snug it up, move to the other end, and do the same thing, then to the middle, then back to make sure it is still on it's mark, If it comes up too far, and grabs the gauge, knock it down with a piece of wood, then move to the next knife, get them set all the same, then torque the jib screws up real tight. Give it a try. Hope this helps.
Posted on May 05, 2010
Replace the drive belt
Do you mean replacing the cutter head drive belt?
With power off start the ribbed belt on the motor pulley, insert allen wrench into cutter head shaft. slowly rotate cutter head while feeding belt onto cutter head pulley. While rotating head, alternate between pulleys feeding it on one rib at a time. Softening the belt in hot water is NOT necessary to install the belt in this fashion.
Complements of
http://www.ereplacementparts.com/delta-22560-type-planer-parts-c-3275_3571_3579.html
Cheers
Billy of Hayward Delta 22 560 Type 1 Planer Parts
Sep 16, 2014 | Delta 12" Portable Planer Model 22-560 W/...
Dw734 planer
More than likely the screw threads are gummed up. Make sure the locking mechanism is up and lower the carriage. Clean the screw threads, spray with WD40 and wipe off the excess. I had the same problem because rarely raised the carriage above 2". Hope this helps!
Jun 30, 2012 | Dewalt Planer (DW734)
Owners manual for a dewalt planer
The Instruction Manual for the Dewalt DW734 Heavy-Duty 12-1/2" Thickness Planer can be downloaded from this link:
http://servicenet.deltaportercable.com/Products/Detail?productNumber=DW734#
Scroll down in the list of downloads to Instruction Manual and select the icon under PRINT DOCS.
May 15, 2011 | Dewalt DW734 Heavy Duty 12 12" thickness...
How do i change the blades
Disconnect the planer's power cord, then use the T-wrench that comes with the planer to remove the four screws that secure the top of the planer. Lift the top to remove it from the planer.
Remove the three wing nuts holding the dust cover over the cutter head. Rotate the dust cover up to unlock it from the fan housing, then push the cover to the left to disconnect it. Remove the dust cover from the planer to expose the cutter head.
Rotate the cutter head with a piece of scrap wood until the lock on the side of the cutter head engages. All eight screws in the cutter head clamp should now be visible. Remove the screws using the T-wrench, then turn the T-wrench upside down and use the magnet in the head of the T-wrench to grab the clamp. Remove the clamp to expose the knife underneath. Use the magnet to remove the knife.
Press down on the cutter head lock to free the cutter head. Use some scrap wood to turn the cutter head for access to the remaining two knives. Follow the instructions in Steps 3 and 4 to remove and replace those knives.
Mar 13, 2011 | Dewalt Tools & Hardware - Others
I need a operator and service manual for a Dewalt 734 planer. Where do I get one?
Here are all the manuals for your planer:
User and parts,
http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
See the right side of the page to download the pdf files. You will have to click the pront doc column where the pdf icons are located. Once you click the pdf icon it will give you the option to either save it or open it. The instruction manual is 9.16 mb
Thanks for choosing FixYa,
Kelly
Dec 28, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
I am unable to raise or lower the cutting surface of my DW734 thickness planer. The turn handle is very hard to turn. Is there some kind of a locking mechanism ? If I had a manual I might be able to figure...
Follow this link: http://servicenet.dewalt.com/Products/Detail?productNumber=DW734
This will allow you to download the manual and exploded art for base, cutterhead and motor. You may also want to check the position of the turret stop. First of all, make sure the cutterhead lockdown lever is disengaged. Here is from the manual:
Your planer is equipped with a turret stop (M), shown in
Figure 11, for repetitive planing of pre-set depths. Stops are
set at 0", 1/4", 1/2" and 3/4". Use the 0" setting when planing
between 1/8" and 1/4".
TO SET A PLANING DEPTH
1. Be sure the carriage is set above 1-1/4" before trying to
set the turret stop.
2. Turn the turret stop until the desired measurement
shows (Fig. 11).
3. Unlock the head lock lever (Fig. 8). Turn the depth
adjustment crank, lowering the carriage by the desired
increments, until it contacts the turret stop.
NOTE: DO NOT USE FORCE TO CRANK THE CARRIAGE
BELOW THE LEVEL THAT THE TURRET STOP INDICATES.
PERMANENT DAMAGE TO THE HEIGHT
ADJUSTMENT SYSTEM ON YOUR PLANER WILL
RESULT.
NOTE: The 3/4" turret stop can be adjusted for other planing
thicknesses. Adjusting the 3/4" turret stop does not affect the
other turret stop settings.
TO ADJUST THE 3/4" STOP FOR OTHER
THICKNESSES
1. Unlock the head lock lever (Fig. 8) and turn the adjustment
handle counterclockwise to raise the cutter head.
2. From the back of the tool, locate the turret adjustment
bolt (N) shown in Figure 11. This bolt is set for a 3/4"
depth of cut at the factory. Use the crescent wrench provided
to loosen the jam nut. Adjust the bolt up or down to
reach the desired planing depth.
3. Turn the depth adjustment crank, lowering the carriage by
the desired increments, until it contacts the turret stop.
Hope this helps.
Dec 27, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
Need owners manual for Delta DW734 thickness planer
look on the right side of the page you can download the parts list or the manual
http://www.dewalt.com/tools/machinery-portable-thickness-planers-dw734.aspx
Nov 18, 2010 | Dewalt Planer (DW734)
Could there be a blown fuse to prevent this from starting, I turned it on and the motor stated for about a blip of second, my electrical panel was not triped though
I answer questions for free.
Your model planer might be different than mine.
My 12" planer has a red reset button on the motor.
There could be a loose wire in the receptacle.
Check the receptacle for power.
Your product manual should have an illustration of the reset button.
The power tool companies do not have manuals for every model number, but they have service centers.
Nov 01, 2010 | Dewalt DW734 Heavy Duty 12 12" thickness...
How do you change the blades on a dw734 planer
Did you save the wrenches for the blades and the setting gauges? You need them. It is hard to do without. You have to take off the dust cover, should be called the finger cover, get the cutter head to lock up, it should have a pin on the right side to lock it from turning, loosen the jib screws,(bolts), and blow out he cutter head. Leave the adj screws where they are. Then do the other side, sharpen the knives, or get the new ones ready, don't answer the fone, or eat dinner at this time. The knife setter sets each knife to the same height and/or depth across the cutter head. It is a small C shaped thing that rides on the head and grabs the tip of the knife when it is at the right depth, they all have to be the same, and they just scrape the knife, they don't pull it or move it, it just touches it. Snug up the jib screw, and move to the middle, check and adj the height snug up the screw, move to the end, do the same, go back to the other end, check it again, use a small piece of wood to tap it down if you have to move it, when it looks good, torque it down, then do the other side the same way. I hope this doesn't have those tiny 2 sided knives in it? They are the worst, they have no meat, they don't cut worth a flip. You need the big knives, something with some meat to them. Check it out, hope this helps.
Jul 17, 2010 | Dewalt Planer (DW734)
Adjustment of sharpened cutter of porter cable 653 versa plane
There are two adjustments. First find the screw on the right side that allows loosening of rear baseplate. Once loose, another screw jacks the base up or down. They are both hex heads on mine.
Turn jack screw until a straight edge along the base just clears the cutter. Spin the cutter once to make sure both edges are the same depth and that both clear the straight edge.
For the front shoe, turn adjustment handle to zero. Remove the adjustment handle from the front shoe and find two vertical slots at the front. Two screws (hex heads) allow loosening of shoe. Once loose, the shoe can be adjusted by sliding up or down. With a straight edge held along the rear base and touching the front base, align the front shoe so straight edge barely clears blade and tighten screws. The front and back base should line up. Replace adjustment lever and recheck zero cut clearance as well as maximum depth. Readjust as necessary. If zero clearance is not an issue, the bases can be set to allow deeper cuts than factory specified. It's a powerful planer so if you're cutting softer woods, a deeper cut might be desired.
Apr 13, 2009 | Dewalt Tools & Hardware - Others
Tools & Hardware - Others Logo
159 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
