Power problems on VCR
After placing a cassette in the unit, the power is shut off after about 10 seconds.
Also, I have noticed the ejection of the cassette is difficult. Sometimes it ejects on command and other times it refuses to move.
Any ideas on what the problem may be?
Your help would be appreciated.
Mike Izon
Las Cruces, NM
  • 1 more comment
  • mizon Mar 27, 2008
    Geno,
    I appreciate your response to my problem. Assuming for a moment one of your three suggestions is the problem, what in your opinion is the best way to troubleshoot and any ideas on the cost involved.
    Would it pay to have this unit repaired or dump it?
    Thanks,
    mizon
  • mizon Mar 28, 2008
    Geno,
    The VCR is an Optimus, model #59, about 12 years old.
    Hope this provides you with a little more info.
    Thanks,
    mizon
  • wworsxx Nov 17, 2008
    I have the same promlem. On LG VCR Model L424, it shows "SAFE" and do not do nothing. I can only insert or eject the casset.
    Anybody know how to turn of safe mode ?
    Thank you!!
    Master:
  • 518 Answers
When a tape is inserted or ejected the machine will attempt to tighten the tape by turning the rewind hub for a second, then it watches the counter to see if the fast foward hub turned (thus the tape is tight), if the tape can not turn or the counter sensor is bad then it shuts off (a safety mode to prevent tape damage). So, you could have a bad belt, bad idler wheel, or bad sensor.
Hope that helps...
Geno
Posted on Mar 26, 2008
  • Gene Wells Mar 27, 2008
    You didn't supply a Make, Model, and age on the VCR. Trouble shooting isn't easy because you need to fake the unit out and make it think it has a tape in it. Then try some functions while watching the mechanics.. Especially the rubber idler wheel that sits between the hubs (if yours has one).
    Something you can try is this: If there's a rubber idler wheel, clean it with a Q-Tip and brake fluid, then dry it off with a clean Q-Tip. Brake fluid will re-vitalize the rubber a bit. Also if you can take the bottom off and get to any belts, clean them with a paper towel and brake fluid. Again, dry with a clean paper towel. Re assemble the unit and try it. If it works, then you need to replace those parts.
    That's about all I have...
    Geno
The VCR accepts the tape and starts to play; then stops and shuts off; when you turn the power back on the tape ejects
You have a transport problem, the mechanism the plays, FF or rewinds is not working.
Someone is going to have to open and look at the unit---as simple as a belt off or broken to the idler (rubber or geared) that doe the actual work, finding a shop that will work on a VCR unit is getting hard as most of the current techs have never seen this type of unit.
What I used to do when I opened one was have a old cassette with the tape removed! but the reels inside of it still there--tape off both sides of the cassette where it opens so the sensors on either side do not try to stop the unit from allowing this.
This way with the unit open and the dummy cassette in you can see thru its top to see if the reels are moving or not and not have the tape get in the way.
Dec 06, 2012 | Magnavox DV220MW9 DVD Player VCR
Power goes off when a cassette is inserted. Tried cleaning heads but it won't even run that. When power is turned back on the cassette is immediately ejected.
Good day!!!
Most common problems
  • VCR refuses to FF or REW and shuts off.
  • VCR shuts off entering PLAY or REC or at random during PLAY or REC.
  • VCR eats tapes.
  • VCR doesn't accept tapes or ejects them without cause.
  • Sound is wavery, fluctuating, or muddy.
The cause for all of these is very often a bad idler tire or other dirty, worn, or tired rubber parts
Sep 12, 2011 | Philips Magnavox DVD/VCR Dual Player
Tape loaded normally but now won't eject. The unit just powers off after a few seconds.
Unplug the power from the combo unit and give it 30 seconds, now plug back in, sometimes this will eject the tape, if not! take the top off the machine and check to see if the tape is spewed in the mechanical section and around the video head, if yes! get a pair of scissors and cut the tape carefully to avoid damaging the video head and remove all tape deb-ri, now power up and eject the main cassette. But! if you find the cassette has loaded in place and the tape is still in the vhs cassette, this would indicate a loading problem with the main carriage, broken belt, bad idler assembly and possibly sensor issues.
Feb 06, 2011 | Sony SLV-D350P DVD Player/VCR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Apr 25, 2008 | Televison & Video
Vcr eject manfunction.
Sound like you have to open your VCR and help it left up to eject. I had the same problem.
Mar 14, 2008 | Philips Magnavox Learning Universal Remote
CST.IN Light
Put a tape in and eject it. It will then work. Just had this problem. CST IN means the VCR thinks it has a tape in. Trust me... Very fixable.
Jan 19, 2008 | Hitachi DV-PF2U DVD Player/VCR
Akai VS-J716EA
Please manually unload the cassette, and refix the cassette mechanism
Nov 06, 2007 | Akai VS-J716EA VHS VCR
Power shut off
The set is still sensin a problem thats why it shuts off, in this units the problem is in the vcr section,check the cassette assambly sometimes is jammed and it will not load or one side of the cassette tray is pushed in too far or misaligned.It will continuo to shutdown until the problem is corrected.Be careful when working on it.
Oct 01, 2006 | Symphonic SC313D 13 in. TV/VCR Combo
Televison & Video Logo
284 people viewed this question
Top Televison & Video Experts
Electro Med Services...
