Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Hi i need to know how to calibrate robinair 347000z mechine
  • sherazmughal Nov 24, 2011
    how i can calibrate to robinair ac machine cool tech ac 375 because i have overcharging problem in this unit so hepl me to get out this probem and tell valid solution about that
    President:
  • 180 Answers
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibration
Posted on May 05, 2010
How to calibrate spx robinair model ac375a
You should not need to unless the unit was damaged.
Mar 17, 2015 | Robinair Measuring Tools & Sensors
Hi, my robinair ac375 wonot charge gas, gauge up arrow and down arrow wont move, we done filter and vaccum oil and reset. it is possible to get special way to reset gauge?
mhkamran.jpg Please check Charging solenoid (S3) in Solenoid manifold block, it may need to change solenoid coil or Rebuild. If charging solenoid is OK, then problem can be SCALE or MAIN CIRCUIT BOARD. See if the machine display show default charging weight 90 kg/lbs when you active CHARGE mode. If not then calibrate scale. But if default charging weight is shown then replace MAIN CIRCUIT BOARD. See attached picture to find solenoids. I wish this will help you to solve the problem. If so please vote for it for further assistance. Best of luck!
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
How do I recalibrate scale on Robinair 34134Z
Robinair Model-34700Z scal calibration follow as bellow:
Press main menu then press up or down arrow till scree appear ''CHANGE DEFAULT'' then press 5454 from the keypad & then YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & then press YES key. now follow the on screen text. Once you calibrate scale then press STOP key to exit.
NOTE: You should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE'' or any other setting it must be on factory setup.
Hope this will help you to solve the problem & if my solution is useful to you please vote for it
Apr 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Hi, I have a robbin 34134z indicates high pressure and do not work. At times it works and then stops working. I can do? . I live in Venezuela and here there is no Robinair agent indicated as repair them. I...
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# May the ISV tank is not overfilled,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Nov 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
How do you calibrate the scale on a robinair 34700z A/C Machine?
Robinair Model-34700Z,for scal calibration follow as bellow:
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key. now follow the on screen text.
NOTE:you should have 9KG/20LBS of weight for scale calibration. Do not change ''TANK TARE''. it must be on factory setup 16.30 lbs OR 7.40 kg.
Hope this will help you to solve thr problem & if my solution is useful to you please vote for it
Aug 27, 2010 | Robinair Cool Tech 34700Z Recovery,...
Over charging won't recover scale don't work
It is not clear which model of robinair machine you have! However your machine need to re-calibrate the scale.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont vacuum
With machine power OFF,remove old pressure transducer & replace new one.now power ON the machine & go for calibration.Calibration step for Robinair 34700Z machine.Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen help text.NOTE:you should have 9KG/20LBS of weight for scale calibration.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
Hi how can i change the oil in the mechine by my self
Press the main menu key,then press upper arrow till screen display "Change vacuum oil".once screen display change vacuum oil then press "Yes" key & now carefully follow the on screen text.
NOTE:DO NOT OVER FILL THE VACUUM PUMP(maximum oil level for vacuum pump middle of sight glass).
Hope this will help you to change the vacuum pump oil.
May 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
659 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
