Question about Acer Aspire 3680 Laptop
Unlock Computer is locked, how do I unlock it?
    Sniper:
  • 66 Answers
You should be able to just click on the user icon and log right in (enter your password if it has one).
Posted on May 05, 2010
Control Locked - The Control Locked feature does not unlock. What can I do to have it unlocked.
Unplug the unit, let it cool down (rebooting computer board), then plug back in, should work fine.
Mar 08, 2015 | Kenmore Elite HE4 Electric Dryer
Why won't the passenger door unlock?
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
A door lock switch lock or unlock actuation
A keyless entry transmitter actuation
An automatic door lock or unlock actuation
A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation.
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K?© resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
I'll post a youtube video on how to test the power door locks computer controlled , check it out ! Your problem could be a switch or the lock actuator , BCM , wiring etc.... you need to test it to see !
I'll
How to test computer controlled door locks
Mar 22, 2014 | 2008 Saturn Aura
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
How to system unlock a gateway desktop computer
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual.
hope this helps
Jul 23, 2012 | Gateway Computers & Internet
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
How to unlock computer
If Error Message Says the Computer is Locked by User
Press "Ctrl" + "Alt" + "Delete" on the keyboard to unlock the computer.
Type the username and password of the user who last logged on to this computer. Click the "OK" button when you are done.
Wait for the "Unlock Computer" dialog box to disappear. The computer has now been unlocked.
Press "Ctrl" + "Alt" + "Delete" on the keyboard again and log on normally by typing in the username and password.
If the Error Message Does Not Tell Who Locked the Computer
Attempt to shut down the locked computer through the server computer. You will have to use the Shutdown tool in the Microsoft Windows Resource Kit (see Resources for download link) to shut down the computer remotely.
Wait for the "System Shutdown" dialog box to display the locked computer. Although the dialog box appears, the computer will not actually restart.
Wait until the "Welcome to Windows" dialog box appears on the locked computer.
Press "Ctrl" + "Alt" + "Delete" on the keyboard before the screensaver becomes active and log on normally by providing your username and password.
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 12, 2011 | Toshiba Satellite Pro L300 Notebook
When powered on the sandisk appears. Then appears a locked lock. I'm unable to perform any other task. How do I unlock the lock?
There are two options by which you can unlock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care
Jul 07, 2010 | Audio Players & Recorders
How do i unlock my windows xp
Windows XP includes a new Microsoft Natural Keyboard shortcut to lock your computer. Any other compatible keyboard that includes the Windows logo key and the Application key can also perform this task.To use this shortcut, press the Windows logo key+L. The following list has different computer lock-up scenarios that are available to you, as well as other ways to lock the computer: Fast User Switching Enabled loadTOCNode(2, 'moreinformation'); If the Fast User Switching feature is enabled and you lock the computer, you can observe the same behavior as if you switched users: The computer returns to the Welcome screen and other users can log on to the computer. Fast User Switching Disabled loadTOCNode(2, 'moreinformation'); If the Fast User Switching feature is disabled and you lock the computer, the Unlock Computer dialog box is displayed that requires the current logged-on user to enter a password to unlock the computer.
Jan 04, 2010 | Microsoft Windows XP Home Edition
My ipod is locked it says enter code and my cousin messed with it
When you lock an iPod nano that is not connected to a computer, you must enter a combination to unlock and use it. ... . You can unlock your iPod nano in two ways ... Connect iPod nano to the primary computer you use it with, and iPod nano automatically unlocks . Note: If you try these solutions and you still can’t unlock iPod nano , you can restore iPod nano.
Jul 08, 2009 | Apple iPod nano
Acer Aspire 3680 Laptop Logo
297 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
