Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
I have an le40a456c20...i get two vertical lines to the left of the screen when i switch the tv on...about 10cm apart. the one to the right gradually fades, the one to the left remains and causes colour distortion to its left to the edge of the screen...can you help.
    Sergeant:
    Champion:
  • 431 Answers
Either a bad controller board or bad panel,if lines are not intermittent bad lcd panel
Posted on May 05, 2010
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 21, 2013 | Daewoo DTQ-14U5SC 14" TV
I have a vizio p42hd TV. It has thin red vertical lines evenly spaced about 3/4" apart throughout the viewing area.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO FIX IT.....
May 18, 2011 | Televison & Video
My 12 year old Sony Trinitron KV-32XBR200 still works pretty well except that it cuts off about 25 - 30 scan lines at the bottom of the screen when cold, then gradually improves somewhat to missing only 15...
No,tv have cold solders inside the tv like vertical IC or around the area.Have a soldering iron,a roll of solders,also know how to do basic soldering?Yes.Take the tv aparts,take a back plastic of the screw driver tabs all around the main pcb,will see the vertical changes,take out the a/c power sourced,resolders those area,will fix this problems.
Feb 10, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Upon turning tv on after it's been off for a while i get two lines going from top to bottom of the screen. theres a line on the left side about 2 inches in from the left thats red and about 3 mm wide and...
HOPE THIS HELP...
Jun 19, 2010 | Toshiba REGZA 47HL167 TV
I have a PS42A410 Samsung that has developed a 10cm black line
Your control board needs replaced most likely. Does it work fine on a cool morning when you first turn it on, then develops the line when it warms up? Good indication it is the control board.
Feb 23, 2010 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Old sony tv gets a bright line in the middle of the screen
Well if this is a tube type, it can be attributed to vertical section. Cold solder on vertical IC, the vertical gone bad or some components on the vertical is at fault.
If your not on electronics better to have it check by a repairer.
Hope this helps.
Jan 18, 2010 | RCA F32650 32" TV
43fdx15b Hitachi 42in red vertical lines magic focus inop for red
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors.Shops usually charge from $200-$300
Sep 26, 2009 | Hitachi Televison & Video
Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Jan 29, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
HISENSE TA42P-HDRA
I am from Tunisia & ibought a tv plasma HISENSE from CHINA 2 years ago;i have a vertical white line(10cm) in the midle of my plasma(Hisense 42"),after 10 mn the tv is on.What can i do?
Oct 31, 2007 | Hisense TA42P-HDRA Television
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
407 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
