Question about Dishwashers
LG LDF7932 Dishwasher Diagnostic Tests - water inlet valve & temp
LDF7932 diagnostic test for water inlet valve (water supply test) in the the Tech Sheet (1/2) MHK61856401 states that ''During fill in the test mode, the digits in the display should increase. Water should shut off at about 285.'' In Tech Sheet (2/2) MHK61856402 it states: ''How to check the water level during a cycle. Press the RINSE and STEAM button simultaneously. The normal water level reading is about 270~290.''
The only display on the inner edge of the door has only 2 digits. Where are these 3 digit readings to be seen?
It also says: ''How to check the water temperature in the tub during a cycle Press the Normal and quick Wash button simultaneously. The display will show the temperature in degrees Celsius. If the heater is on, the displayed temperature should rise.''
Where is this reading to be seen?
Also, when reading the Program Chart, do the numbers represent minutes? In the Normal Cycle, there are 5 different rows. What does each row represent?
Thanks
bbtoast
  • 319 Answers
SOURCE: Bosch SHU9915uc/u12 making noise
TJ
I have a possible answer to your diagnostic test, see below, if this doesn't help, let me know, and I will provide more help!
Brian
SHU 991x/992x (Integra) MODELS
To start test program, press and hold both POWER SCRUB PLUS and REGULAR WASH program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, SCRUB WASH, REGULAR WASH and RINSE & HOLD), press and hold each program button. When SCRUB WASH program button is pressed, CLEAN light also comes on andan audible tone (?beep?) also occurs.
To start testing, press both POWER SCRUB PLUS and REGULAR WASH buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
SCRUB WASH = Water filling fault (over or under filling)
REGULAR WASH = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), SCRUB WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), REGULAR WASH light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Posted on Jan 19, 2008
SOURCE: Kenmore Elite 15962990 will not start
So far, I'm not very impressed with this website. I posted a problem with a Kenmore Elite 15962990. FixYa emailed me back, saying: "We wanted to find out if you still need a solution for the Kenmore 24 in. 15932 Built-in Dishwasher Problem". So now I'm confused. I'm supposed to trust advice from somebody who can't even get the model number right? And FixYa keeps telling me I'm dealing with a top load clothes washer instead of a dishwasher.
Anyway, the problem still exists. I know there must be some way to reset it or put it in "maintenance mode". But none of the button sequences I saw online will work because my specific model does not have the buttons mentioned.
Posted on Feb 11, 2008
issy2
  • 460 Answers
SOURCE: stuck in two minute drain cycle
Hello sir
Posted on Feb 25, 2008
  • 3422 Answers
It is possible that the unit has leaked.
I want you to please check THIS link it will solve your problem.
Don't forget to do the banging test mentioned there.
Goodluck..
Whirlpool Cabrio top load washer bleach and detergent will overflow.
Change the bleach dispenser.
Also make sure the tubes are not slightly clogged from residue build up of mildew.
Dec 01, 2014 | Whirlpool Washing Machines
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
There is no water going into the dishwasher.
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 08, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 26, 2009 | LG Dishwashers
Keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Sep 24, 2009 | LG Dishwashers
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG ld-14aw2 dishwasher
Possible cause:
Remedy:
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
LG Dishwasher (LDS5811) - low water level
1E= Inlet Error
Condition>>>
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 20, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH
E1=Water inlet Error
Causes:
(below 10 psi)
Inlet Valve is OK?
by impure water.
Solutions:
device.
by the Test Mode.
Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
462 people viewed this question
Top Dishwashers Experts
Owen Barnes
