Question about Gestetner Office Equipment & Supplies
GestetnerDsm516pf All-in one print/copy/fax problem with Fax Fax receive/transmit does not work when toner cartridge is empty. Replace with recharged toner cartridge but empty toner message still appears and Fax still doesn't work.
I'm surprised you're trying to make a buck off this kind of stuff. Instead of being part of the solution you're part of the problem. Easy one .....get the service manual. Mfg has rigged it so you must buy New cartridge unless you can discover the key to reset counters.
Thanks
Posted on Mar 27, 2008
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Incoming fax does not print, and also cannot get printout of faxes received. Memory was received. Regular printing and photocopying works fine.
if you found the msg on lcd like "toner empty" & red light near the lcd
then you have to reset toner counter through tech mode.
MENU # 1 9 3 4 MENU pres continues you will find tech mode on lcd
then press 3 times right arrow key "new cartridge" will come on lcd bottom line
then press 2 times ENTER button & swicth of the macine for 5 second then on
all samsung mfds stop printing FAX when "TONER EMPTY" msg comes.
Feb 10, 2011 | Samsung SCX 4521F All-In-One Laser Printer
BLACK LINES WHEN TRANSMITTING ON THE PANAFAX UF 895 AND WHEN PRINTING A COPY BUT NOT WHEN RECEIVEING A FAX NOT THE TONER CARTRIDGE
If the lines are thin, open the document feeder by pulling up on it and clean the small glass.
If they are 1/8 inch or wider, some elements are burned out in the LED scanner assembly.
Mar 27, 2010 | Panasonic Office Equipment & Supplies
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Toner Empty
it it was receiving fax before replacing the toner then it still should be able to receive so just turn your printer once off and turn it back then see what happens.
if problem still remains then please post back.
and rate all answers.
Feb 11, 2009 | Lexmark X215 MFP All-In-One Laser Printer
Replacing toner
Call Dell Tech Support. They can walk you through a "hard" reset that includes turning the printer on and off while having the tray open, holding down certain buttons, etc. If error returns, it could be that your fax module is in need of repair or something has broken on the toner cartridge. If this only happens when receiving faxes, I would suspect the former.
Jan 26, 2008 | Dell 1600n All-In-One Laser Printer
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
64 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
