Question about AGA Six-Four A64DSI Dual Fuel Range
My electric aga has gone cold - AGA Six-Four A64DSI Dual Fuel Range
Could be one of two things, is the fan still running or is it the conventional oven which is cold? If its the fan oven then it probably is the element (most common) at the back where you see the fan blade. it is a circular element. Conventional oven has two one top and one bottom. You must have the neon on the front come on or the problem is with the thermostat.
Posted on Feb 17, 2011
  • AGA Master
  • 43,501 Answers
If your electricmy electric aga has gone cold - 2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 06, 2010
Stop my gas aga squeaking
Probably not, but you may be able to replace them. Remove them from the fan if possible, take them to any industrial supply, they should be able to match them up, they usually cost only a few bucks.
Feb 19, 2015 | AGA Companion Dual Fuel (Electric and Gas)...
Toyota 4runner problems
check for an over heating situation with the motor as what you say indicates engine over heating.
Jan 23, 2014 | Cars & Trucks
Lamp bulb gone
What is the make and model?
Mar 11, 2013 | Televison & Video
AGA ERROR IN TALLY 2265
either your aga motor is bad or your board set is bad. Turn unit on watch the printhead while opening the cover. The printhead should move back and display "cover open". When you close cover the printhead should move closer to paper. If not bad aga motor or bad board set.
Dec 15, 2010 | Tally Dot Matrix T2265C Printer
Hai , i have tally 2280 sprintpro printer.now it
problem with aga gear open the printer & check the white gears situated left upper of aga motor .......
or
may be aga flag missing or misalinged
Jun 29, 2010 | Tally Matrix T2280 Printer
My nightstore electric aga has a red flashing light and is clicking , what is happening please ? Thanks in anticipation .
Just out of interest, did you work out what was wrong with your Aga, as ours is doing the same thing having been turned off for a month. We would be really interested to know what was the reason and the solution. Hoping its not too major. Many Thanks.
Apr 05, 2010 | AGA ALEG36-E-CD Electric Kitchen Range
Aga not lighting
you have an electric head on you BM valve if you turn off the power the valve will shut off if you want it to work with no power i.e. in a power cut you push the lever on the top of the electric head to the left and behind the stop so it doesnt return and the bm valve will be on manual
Dec 03, 2009 | AGA Kitchen Ranges
Printer-Genicom 2280+ Printer stopped then continued working, often on LCD Hardware error. When turn on printer- on LCD AGA Error.
The AGA Error on the 2280+ indicates the Automatic Gap adjust is not working.
This may be caused buy;
An obstruction (eg paper jam, ribbon etc) preventing the AGA from working correctly.
The AGA flag becoming detached from the printer or damaged
An incorrectly fitted print head
Fault AGA sensor.
You can overcome the AGA error by disabling the AGA and manually setting the print had gap.
To disable the AGA
Power the pritner on holding down ONLINE, keep ONLINE held down whilst the printer initializes.
When the printer displays ASCII80 ASCII136 release ONLINE
Press NEXT until you see AGA
Select AGA and set this to OFF
You can then manually adjust the print head gap in the normal menu.
Menu>Adjust>Head change the value to increase or decrease the head gap as required.
Jul 21, 2009 | Tally Matrix T2280 Printer
I don't know how to tell the amp ratings of these fuses
Electronic - PC Board and Small Dimension Fuses - PC Board & Small Dimension Fuses 1/4” Dia. x 5/8” to 1” length ferrule fuses
AGA Specifications Decription: Fast-acting fuse. Dimensions: 1/4· x 5/8· (6.4 x 15.9mm). Construction: Glass tube. Ratings:Volts- 125Vac (or less)
Amps- 1/16-30A
IR- 10,000 (1/16-11/2A @ 125Vac)
- 200A (2-5A @ 125Vac)
- 1000A (6-30A @ 32Vac)
Agency Information: CE, Std. 248-14, UL File E19180, UL Listed, Guide JDYX 0-11/2A UL Recognized, Guide JDYX2 2-12A. Features and Benefits: · Fast-acting for maximum protection.
· Size rejects insertion of other fuse types. Typical Applications: · Electronic Circuits Catalog Number Amps AGA-1/16 1/16 AGA-1/10 1/10 AGA-1/8 1/8 AGA-1/4 1/4 AGA-3/8 3/8 AGA-1/2 1/2 AGA-6/10 6/10 AGA-3/4 3/4 AGA-1 1 AGA-1 1/2 1 1/2 AGA-2 2 AGA-2 1/2 2 1/2 AGA-3 3 AGA-5 5 AGA-6 6 AGA-7 7 AGA-7 1/2 7 1/2 AGA-10 10 AGA-15 15 AGA-20 20 AGA-25 25 AGA-30 30
Apr 11, 2009 | Electrical Supplies
AGA Six-Four A64DSI Dual Fuel  Range Logo
536 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
