Question about Toshiba TECRA M9 Notebook
No video in the display
There is a problem with my tecra m9, i don´t see any video in the display, sometimes using a CRT monitor with a different resolution i can see something but very bad image.
    Guru:
  • 1,481 Answers
Gues the LCD display is not working,
1 the LCD screen is out or
2 the backlite inside the LCD screen is out or
3 the invertor board behind the LCD screen inside is out.
Posted on May 05, 2010
My tecra is displaying verical lines all over the screen, even with external drive
it could possibly be the ribbon cable that transfer the signal from the base of the laptop to the screen is damaged or loose.
Try wiggleing the the screen to see if image changes take to repair shop to replace.
Aug 10, 2014 | Toshiba TECRA M9 Notebook
Laptop is connected to the external LCD monitor, the monitor is on but screen is blank
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor AND external monitor source
3) External monitor source ONLY
Hold the Fn key down, and tap once on the F5 key.
Hot key through until you find the setting you want.
Release the Fn key
Regards,
joecoolvette
Apr 16, 2013 | Toshiba TECRA M9 Notebook
Crt monitor height are coming very small in size picture wat probelm
Did you set ur resolution screen setting higher than 1024 in ur computer panel resosulion setting?Yes than that is ur problems right there.CRT monitors modes are based on old technologies ,CRT monitors can't go up more than 1024 resolution setting.Setting resolution more than 1024 resolution for CRT models monitors will have thesse causes.The screen resolution on the screen will shrink and get smaller or will not have video resolution on the CRT monitors screens at all.Only LCD or LED monitors models can support and go higher than 1024 resolution setting has none of these causes.Time to upgrade for a new monitors technologies like LCD or LED monitors models.
Oct 17, 2012 | Computers & Internet
When I turn my Toshiba Tecra M9 on it is completely black, beforehand it beeped a lot when it started up and then the screen was covered in a's then when it was actually started and up and running the...
Try hooking it up to an external monitor (or LCD monitor) and see if the same thing happens (first attach a monitor then do a cold start). My suspicion (from the a's you described) is that the motherboard is bad - I call it garbage video. Toshiba dealers will probably charge too much for these replacements. If you're a DIYer or you know a reasonable shop that knows laptops, then eBay would be a good source for replacement boards.
Sep 02, 2011 | Toshiba TECRA M9 Notebook
Come to work Monday (today) and turn on monintor , light up for a second and then off and now will not come on. Used another monitor on pc , no problem. This is the second monitor that did it to me.
is this a crt monitor or a lcd monitor? if it is a lcd monitor then your problem is a bad back light power inverter board and needs to be replaced. if it is a crt monitor then check the brightness and contrast controls on the crt monitor.
also check to make sure that the display are compatible with the crt monitor as well! meaning that if the crt monitor's max resolution is 1024x768 and your video card is set to a higher setting then you will get a blank screen with a sometimes green power light, maybe flashing. be very careful though because may also damage the crt monitor. also check your video card setting to make sure it is at 50 hz or 60 hz some crt monitors don't like the higher vertical refresh rate.
one last thing is the age of the crt monitor, it may be on its last leg of life. when i worked at a monitor repair center a few moons ago there was a life expectancy of maybe 30,000 hours(?) on a crt(note: it's been awhile so please don't quote me on this life expectancy!)
you may get eye strain with higher than 60hz range.
Aug 22, 2011 | Westinghouse Computers & Internet
Can I connect 3 external displays to a Tecra M9? Can they be different resolutions? Additional drivers? Hardware to connect from the monitor port?
You can. You need to buy a VGA Distribution Amplifier that will allow you to connect multiple compatible monitors or projectors for simultaneous viewing.
Good Day.
Jun 23, 2011 | Toshiba TECRA M9 Notebook
What jumpers do i need to short in the toshiba tecra m9 to reset password. THANKS
i have toshiba tecra m9, i get the error massege when i on the laptop. the error massege is "PCI Express error". plz help how to remove this massege...thax..
Jan 04, 2010 | Toshiba TECRA M9 Notebook
Tiny Monitor
Out of frequency means your video card is trying to display a resolution beyond the capability of you monitor. Typically it is really a combination of too high a resolution and too many colors. Typically a 19? CRT will be set to display at a screen resolution of 1024 x 1024 with the color quality at 32 bit or *true* color. Personal preferences differ and you can set it lower or higher, depending on the capabilities of the monitor. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 02, 2007 | Tiny Computers B1996 19" CRT Monitor
Toshiba TECRA M9 Notebook Logo
159 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
