Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Can't find my files
I see all the WD sync files .. but none of my personal files. i click on the setup to have the program installed in my laptop .. (VISTA) Sony Vaio - i get windows detected a problem and it closes.
please help
5 Suggested Answers
Beni S-P
  • 1006 Answers
SOURCE: Installing and Using WD Passport Port. Hard Drive
Reapiring OS will fix your problem
Posted on Jan 27, 2008
  • 7 Answers
SOURCE: wd passport file customizing
If you open the Computer directory and identify the drive letter for the WD Passport drive, right-click on the drive folder and select properties. The properties tool for the drive will open showing several tabs. Select the Customize tab and you will see a heading for "use this folder type as a template" with a drop down menu. Here you can select different categories for the folder and apply it to subdirectories also by checking the box below. This should give the folders more of a vista look! If you want to personalize further and add your own images to the folder icons you can also do this here. If you don't select the apply to subdirectories option you can manually apply different styles to different folders in subdirectories. If you don't like the way things have turned out you can also restore the default settings.
Hope this answers your question.
Have fun
Posted on Dec 08, 2008
  • 181 Answers
SOURCE: Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
Posted on May 29, 2009
JulesPCaut
  • 702 Answers
SOURCE: Sony Vaio laptop could not access 1TB external hard drive
Check the Disk Manager in Windows to see if the drive is formatted and has a drive letter assigned.
Also see further troubleshooting on external hard disks.
Posted on Oct 20, 2009
How do I use a program ive just downloaded on this laptop
Hi
Usually the files you download for programmes are ".exe" or ".zip" files. In the case of ".exe" files they are either executable, in which case you need to double click on them and follow the instructions to install the programme, or they are self-extracting zip files where you again double click on the programme, it will ask you where you want the files expanded to, and once expanded you need to find the "Setup.exe" file and double click to install the programme. ".zip" files you have to expand manually and then double click the Setup.exe" file to install the programme.
Incidentally you must have administrator rights to install programmes, if you are a standard user, most likely, then you must either run the programmes as administrator (right click on the file and click "Run as Administrator" in the menu that comes up) or log off and log on as an Administrator with appropriate password.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 29, 2014 | ASUS X53E-RS52 15.6" Laptop Computer,...
Whats the best way to transfer my infomation and programs to a newer computer
For content, if you don't want to transfer it all to a flash drive and then transfer it to the new machine, register for an account at any (or all, your choice) of the following sites:
Dropbox (2GB free)
https://drive.google.com/ (15GB free)
Welcome to OneDrive (15-23GB free)
Once the programs of your choice are downloaded and installed, use them to back up your personal files to the internet. Then, on the new computer, install the programs and allow them to sync. This will download them from the internet. Move the files out of the folders to free up space, wait for the removal to sync to the old computer, and go back to the old computer to move more in to be moved over. Repeat this as much as needed to have all of your files moved over.
For programs, transfer any installation files you still have (the program you download and then click to install) through the cloud storage programs from above that you choose, then use these .exe files to install to the new laptop. If you don't have the .exe files lying around, then you can either hunt them down individually on the new computer (in which case, make a list from your old computer) or use a service like
Ninite Install or Update Multiple Apps at Once (it's free, by the way) to mass download/install most common programs so that you don't have to go hunting for them.
For programs that were installed via disc, you're probably just going to have to install those on the new machine the old fashioned way. You cannot just copy/paste program folders (though it's tempting) because installing programs writes values to your computer's registry, which cannot be transferred and certainly don't tag along with the program files installed on the computer. These registry values are what tell the computer how to handle that installation, so while some programs MIGHT work, most will not work well or at all without.
Hope this helped!
Aug 15, 2014 | Computers & Internet
I've a htc trophy. i need pc suite for my htc trophy.how can i get or download it?
Here is Download link HTC 7 Trophy Sync version 3.0 driver for connect to PC Windows. Here also give information about how to install this software. The software HTC Sync PC Suite are ready to download. Please follow the instruction bellow :
  1. Please click Download below to download HTC 7 Trophy Sync to your PC.
  2. Run file setup to install it to your PC.
  3. Follow the Install Shield Wizard to finish the installation.(Suggestion: Please close all running programs and temporarily exit your anti-virus program when you install the HTC Sync).
  4. Select the "Complete" Setup Type for faster and easier installation process, and then press "Install" to begin the installation. (For advanced users you could choose "Custom" to change the pre-defined shortcuts and the installed application folder path by your own.)
  5. After you saw the Install Shield Wizard Completed, please press "Finish" to exit the Wizard.
  6. Use the USB cable to connect your phone to the PC
  7. Now you can start HTC Sync.
http://mustikamax.com/2011/03/09/download-htc-7-trophy-sync-version-3-0-driver-pc-suite-for-windows/
May 09, 2011 | HTC 7 Trophy Cell Phone
How do i install or remove any programs in Imate
You can download the file to your system, from the website, if you already have the program you can install with 2 procedures.
1. Normal Setup installation 2. .Cab Installation
1. For normal installation , you have to install Microsoft Active Sync 3.7 for your Imate Jam Normally the programmes comes for the imate having the setup files
How To install a program: Simply run the setup of the program you wish to install, make sure you phone is connected and active sync is running, Setup will run and it will ask you where you have to install the prog in Memory card or phone memory and you will see notification on your phone for installation
2. .Cab installation You copy the .cab file of any software into memory card and run the cab in your phone, it will ask you to install the program and just follow the on-screen instruction and you will be able to install the program in your phone.
You can get imate Jam software from the following websites Getjar.com gallery.mobile9.com
feel free to reply to this post if you require more assistance,
Regards, BA
Jan 15, 2011 | i-mate JAM Pocket PC
My WD wants to install syn software. None of the files look like the files originally pulled for backup. My hard drive crashed and I need to restore to a new Hard drive - what do I do?
When you connect the drive, ignore the sync option. Do note in your "my computer" WD will have two drive letters (one is a read only drive) that contains the sync software. The other drive letter will be where you data is stored. If you used the sync software to backup your files; you need to install to get your data back. If you simply copied your data from one drive to another; the files should be there in their original form.
Oct 18, 2010 | Western Digital WD Passport 250GB Portable...
I tried to download itunes to my Acer Aspire 5517 laptop. Once I download the program there is a window that appears and it says: "Choose the program you want to use to open this file." None of the...
Did you download itunes form the Apple Official website? If not, click here to download (if so, don't do it again). After it's downloaded, go to the download folder and right-click on the itunes setup (itunes you just downloaded), click "Run" or "Open", don't select, "Open with" or "Autoplay". I hope this will help you install it.
If you have further problem, let me know.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Acer Aspire AS5517 16GHz AMD Athlon 64...
Help to backup full computer programs & docs with WD Passport 160
Try going to the "Computer" icon and look for the external drive. Open the ext. drive folder and look for the InstallSeagateManager icon, the Application one. Double-click on it and it will allow you to install the software to do a backup on your new computer. First thing you should see is the Language Selection screen. I think you can take it from there!
Sep 22, 2009 | Western Digital Passport (WDXMS1600) 160...
WD Passport Elite 320 - won't install autobackup launcher
I just spoke to WD support...here is how to solve your problem:( I had the same problem and it works great now)
1. Connect your WD ext. drive.
2. Click open Computer.
3. Double click open the WD blue icon.
4. Double click open WD_Windows Tools.
5. Double click open WD drive manager.
6. Double click open the Setup icon for Vista 64 (the other icon
is for x86 windows)
run the setup and it will take care of your problem. enjoy!
Dec 01, 2008 | Western Digital Passport WDXML800UE...
Symantec antivirus corporate edition, getting it on my laptop without cd rom
The files you copied are the installed files which is installed by the install shield wizard(or setup file).The installed files do not contain the setup or install shield file. You can use the software by double clicking the .exe file (most probably by names starting with rtv or sym).if everything goes successfully symantes icon will appear on the task bar.
May 21, 2008 | Computers & Internet
My Book 750 GB/GO
Hi Corson,
I've seen this type of issue before when a MyBook was connected to a legacy (1.1) USB port on an older computer or a laptop. Do you know if you're using a USB 2.0 port to connect to the drive?
Ben
Mar 03, 2008 | Computers & Internet
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
105 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
